Installing 240V Service To Your Shop - Price Breakdowns...
   / Installing 240V Service To Your Shop - Price Breakdowns... #21
   / Installing 240V Service To Your Shop - Price Breakdowns... #22
Me, I would like 3phase. There is so much quality used machining gear that due to being 3 phase sits on craigslist forever. I know you can get the transformers but it would be nice just to have it.
I agree, but unfortunately 3 phase is not available everywhere (around here anyway). I had to put in a 35 hp phase convertor in my shop. By the way, I have 400 amps in my shop.
   / Installing 240V Service To Your Shop - Price Breakdowns... #23
Thanks - If I read that correctly #2 would be good for 94 amps. #6 is good for 37 amps.
Try this chart. 6 gauge copper should be 55 to 75 amps depending on if it is Romex or not and temp rating. 2 in copper is 95-130 depending on type of covering. Ampacity Charts Note that aluminum seems to be about 20-25% less ampacity in the same size guage.
   / Installing 240V Service To Your Shop - Price Breakdowns... #25
Why would you need the 50amp in the shop? Just asking. :)
I need the 50 amp receptacle for my welder, thats what it requires. You may need the 50 amp breaker in the shop to act as a main disconnect. Check your local codes, you may or may not need one but it is still a good idea to be able to cut the power to the shop with the flip of a switch in an emergency.
I don't think its required with a sub panel. I did put a disconnect switch in my garage, so I could work on the wiring when I wanted to, or shut the whole garage down, but I don't think its required. Anyhow, always best to check codes, get permits, etc... ;)
   / Installing 240V Service To Your Shop - Price Breakdowns... #27
My shop is already wired, regettably, old fuse boxes where used. When I moved in to the house, there was a overhead wire ran from a breaker panel in the basement of the house to the shop. Dad worked for the TVA and had brought home some aluminum wire like is strung between powerpoles. I dont know the guage, but its pretty hefty. When I moved in the house, I didnt like the overhead wire so i bought the plastic conduit and buried the wire to the shop. My breaker panel in the basement of the house is a 200amp box, fed from the 200amp box off the carport. The basement 200amp box contains a 100amp breaker for the shop, as well as the breakers for the heatpump, well pump, basement lights and outlets. Lots of things i dont like about the wireing in this house and the shop. Some things I have changed over the years, like getting rid of all the 220v circuits in every bedroom, and adding gfci outlets in the bathrooms and kitchen. And I am planning a do over in the shop this week. I have done about all I can to fix the wireing in the house, short of knocking down the sheetrock and starting from scratch. In the shop, I will be getting rid of the fues panel and going with a breaker box. Probably a 100amp main since 100amps is whats in the breakerbox at the house. I think I will look and see if I can find a 125 or 150 amp breaker for the house box to get more power to the shop. If so then I might install a bigger breaker box in the shop. I guess I need to measure the wire run and gauge before buying anything.
   / Installing 240V Service To Your Shop - Price Breakdowns... #28
220 would be nice to have in the bedroom to run a electric heater. I have a rental and the guys renting it wanted a hot tub outside. they got estimates to rewire the house for 8,000 dollars. I do hate renting more each day.
   / Installing 240V Service To Your Shop - Price Breakdowns... #29
What is wrong with aluminum?
Tons of residential services are fed with al. In fact copper feeders are uncommon in my area.
   / Installing 240V Service To Your Shop - Price Breakdowns... #30
The wires are bigger and harder to handle for the same ampacity.
Found another calculator designed for pump applications.
here for a 3% drop:
Inputting 240 volts, 50 feet, 60 amps it requires #4AWG.
Inputting 240 volts, 50 feet, 100 amps it requires #1AWG.
/edit - I don't trust that calculator
The site Jim references, electrician2.com voltage drop calculator shows for the OP to run 100 amps 4 ga would do.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
