Installing ceiling in a 10' high garage bay
   / Installing ceiling in a 10' high garage bay
Dusty said:
Usually you put the ceiling up first so the wall boards then hold up the edges of the ceiling.
1*Any reason that you started with the walls first?
2* Did you use nails or screws? Dusty
1*I Needed the partition in place to get the width of the ceiling. The trusses are 4' OC
2*Screws
Later plans are to partition the rest of the building into 3 rooms.
One of those rooms will have a ceiling and the other two will not.
   / Installing ceiling in a 10' high garage bay #22
My celling is 12ft, I got lucky buddy of mine picked up some racks from
Toy's R Us you know the green and orange ones, worked great for scaffolding.
When done he let me keep one rack also :)
FWIW here's a tip for ceilings, I used the same metal thats for the outside
of a poll-barn.
My building 30X48 so 14ft sheets worked perfect inside.
The real nice thing is this stuff is already painted, shoot it up and it's done!
I then had insulation blown in on top of it.
I had no desire to use the attic for storage.
This worked out very well for me, I bought brite white, no painting!
I used 3/4in OSB on the walls took 2 heavy coats of primer and 2 heavy coats of paint. :( I hate to paint!
You'll find a few pic's of my ceiling here
Shop Lift pictures from off roading photos on webshots
Gene
1*FWIW here's a tip for ceilings, I used the same metal thats for the outside of a poll-barn.
My building's 30X48 so 14ft sheets worked perfect inside.
2*I used 3/4in OSB on the walls
3*took 2 heavy coats of primer and 2 heavy coats of paint. :( I hate to paint!
Gene
1*That would be nice for walls too so you could wash cars and use a garden hose in there. Metal is a bunch more expensive than OSB though
2*Why such over kill with 3/4" OSB.I used 1/4" and it's a lot stronger and tougher than drywall so that's plenty good enough for me.
In my other Pole building I intend to use about half 7/16 and half 1/4 OSB.
3* I'm not going to paint mine - paint problem solved. If I was going to do something along those lines I would stain it not paint it, Much easier and quicker than painting.
People seem to think OSB makes a room to dark. But I can't see where it's any different than paneling plywood or and unfinished garage wall.
   / Installing ceiling in a 10' high garage bay #24
of a poll-barn.
Gene
Awesome!! I like the painted OSB walls. You can't even tell it's OSB.
   / Installing ceiling in a 10' high garage bay #25
Yep, but I wanted smooth walls, I do all sorts of heavy work in this building
strong walls are a plus for me.
3/4 maybe a little over kill but I'm happy.
It's also studed out with 2X6's
All the trim around the windows and doors is 1 1/2 in angle aluminum, again no paint.
The way I've got the walls painted with a high quality outdoor paint
once or twice a year I empty the building and take the power washer
to the whole place!
To each their own I'm just sharing what I've done with my building.
I spend a lot of time in this building so being clean, brite & stout is a must.
I may be a bit of a extremist too ;)
Gene
to the whole place!
1*To each their own I'm just sharing what I've done with my building.
Gene
1* Congratulations on a great job well done-very nice.
I didn't need this elaborate for my stall - It was just a place to get me in out of the cold weather this winter so I can tinker around getting some things done that I couldn't do otherwise during bad weather. I installed the heat in it about a week ago.
This is not the ultimate plan or stall on my final scheme of things.
I have another stall 16 wide by 22 feet deep to partition off in this same structure, for my BX 23.
This building is 76'long by 22'deep
When I get that one done the building will have 4 rooms in it.
1*36x22
2*16x22
3*12x22
4*12x22
I still have another 52 foot wide by 30 foot deep pole building to section off into 2 26' wide by 30' deep rooms for a 2 car garage in one room and a combination work shop and 2 car garage in the other room.
This whole building gets central heat and air.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
CATERPILLAR D4K LGP CRAWLER DOZER (A60429)
CATERPILLAR D4K...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
