installing wheel weights conveniently
   / installing wheel weights conveniently #11
On my weights, I only have to put them on once, and then I still have access to the wheel bolts. So when I put them on, I first took off the whole tire/wheel, and laid it down, but set up on a couple scraps of 4x4, so I could get my arm under it to hold up the carriage bolts from below. Laying the weights into the rims is still work, but then they will slide around until you line up the holes. It is easy to stand up the completed assembly and get it back onto the tractor.
Are you guys trying to find an easier way to do this 'cause you put them on and off frequently? Is this for mowing or something?
   / installing wheel weights conveniently #12
:):Dtoo late i "Clicked' im tired now gotta go nap
but simple and good idea...
Thanks very much to all of you:
Brian for remembering the right source and finding the link.
Schmism for pasting in the picture.
Runner for the picture of the jack adapted to boat motors
Travelover and Flusher for describing your overhead lifts (nice old moldboard you have sitting there, Flusher).
Dirtworksequip, I wish I had weights the same style as yours. Mine are solid, dense little chunks and hard to get a hold of.
That little floor jack with the right angle fastened onto it is close to what I had in mind, but it's even simpler (the jack, not my mind). I'm going to modify both the design in the picture and my first idea. I will post a picture when I get done (which really ought to be before I have to plow snow but may have to wait till later).
JD sells a second set of weights to bolt onto the 50lb weights I already have. But I think I will use an idea I saw discussed on several other threads: just make my own out of old barbell weights. That should be cheaper anyway. JD certainly has a high opinion of pieces of metal that they have painted yellow.
In answer to a question: Yes, I do need to put the weights on and take them off fairly often because of the number of different things I ask my 2305 to do. It does them pretty well, by the way.
   / installing wheel weights conveniently #14
I work for General Electric Transportation and build locomotives in Erie PA, I was able to get some cutouts from our burn area that are 3/4" thick and just about 12" diameter, just fits in the wheel perfectly. I drilled a 1" hole in the center then made 2 brackets out of 2" wide by 5/16" thick long enough to mount to the factory weight holes and welded a 1" round bar in the center bolted them on and leave them on all the time. They weigh about 25lbs. each and I can just slide them on one at a time. I can put 6 or 7 on each wheel without sticking out past the tire. I hold them on with a 1/4" lynch pin. Very easy to install or remove, I had the tires on my old tractor(a ford 1310 19 hp 4x4) loaded with calcium cloride for a long time but didn't like the ruts in my yard in the spring so I came up with this design it works great and cost was about 10 cents per pound from our onsite scrap yard. PS since the price of steel has gone up it now would cost me 15 cents a pound still a bargin don't you think?
   / installing wheel weights conveniently #15
I have weights for my small cub cadet. I think they are 75-80lbs each. About 20lbs more than I could handle without killing myself or breaking something.
All I did was build a small platform that put the weights at the correct height. I would lift the weight on the platform and slide them into place. One of the things I've found handy is the have and extra threaded rod on hand that it is longer than required to help get things started.
Not sure what your design is but is really doesn't need to be too elaborate to work. The nice thing about the platform was I didn't have to counter balance anything.. Just push up to the wheel and put the weight on and go.
Wedge
Well, I promised to post the results of my project. I had some help from a local machine shop to size and drill some small pieces of metal that fit into the head of my floor jack. The machine shop also drilled holes to make the rotor you will see in the pictures. The rest of the supplies were cheap bolts and fittings from local hardware and plumbing stores. The finished product is a little front-heavy, but I can balance it with my knee for now. Eventually, I am going to build a counterweight off the t-joint you can see in the pictures. From here I'll just let the attached pictures do the talking.
   / installing wheel weights conveniently #17
Nice job, looks like a real knuckle saver. :)
   / installing wheel weights conveniently #18
Where were you when I was putting the weights on my cub.. Even though I had an ok system this would work much better. Nice setup.
Wedge
   / installing wheel weights conveniently #19
Nice job Coles. I see you applied the K.I.S.S principle and it worked out perfectly!
   / installing wheel weights conveniently #20
Looks like a winner!
Nice work.
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
*Selling at Royal Auction Tampa, FL Location* 5 (A59228)
*Selling at Royal...
Utility Cart (A59228)
