Insulation for shop ceiling
   / Insulation for shop ceiling #61
Thank you to all I'm going to order some liner panel for my ceiling for mine definitely looks like the best option. Just not looking forward to having to move everything to do the install.
   / Insulation for shop ceiling #62
Yeah, that part sucks. I did the same thing. I was in my shop 4 years before I added the liner panel and more insulation. Had 4" of vinyl faced fiberglas thru that time. I had to take my electrical conduit loose and slide the panels over top of it. What a PITA. Should have done it right in the beginning.
My shop has always been relatively easy to heat. But now I noticed a dramatic difference. I use a wood stove and a propane furnace. Leave the furnace thermostat on 60. It takes over in the wee hours of the morning so I don't hafta worry about stoking the wood stove. Biggest problem I have now is when it's in the 30s I get it too hot in here real quick when I light the wood stove. But I'll deal with that. :)
Make sure to post pics of your progress when you get started. We like to watch members spend money and tackle difficult tasks!!! :)
   / Insulation for shop ceiling #63
Very informative. Thanks for the ideas. Chomping at the bit for a pole barn
   / Insulation for shop ceiling #64
Yes, They make screws for fastening metal panels to wood, no drilling required.
Standard pole barn screws...they have a rubber washer on them to serve as a seal and more importantly to "snug" the panel without wrecking it. Not cheap (but what is)? Available in several colors. Your metal supplier should have them but basic colors are available at Menards so I assume all the big box stores have them and your local hardware store might also. I recall they are a 1/4" hex head but check. I think a layer of poly sheeting is important. Prior to install you can choose to "block" the soffits with suitable material if your building has a ridge vent and perforated soffits (they serve as your ventilation system to carry out excess heat and moisture). You don't want to fill them with insulation. I think corrugated cardboard blocking is available but I think I heard that it will disintegrate with time. As noted previously I opted to form a "bank" around the perimeter with thick fiberglass batts (2 layers that got to R-50) then used blown-in material to fill in the field also to R50. My 30x40 heated space cost $1,000 (hired out) to insulate. You'll want to have some way to "navigate" above your new ceiling so plan ahead there (as noted previously I had 2X4's strung 10' apart on top the bottom cord of the trusses...I know you aren't supposed to place too much weight on them but if careful you'll only stress them once (insulation install) and then you'll have your nailers for lighting and lightweight hanging stuff. I do believe that you are going to love your finished product. It will look nice and you'll appreciate the light reflection. Good luck! Btw, I promised a picture but my phone camera didn't seem to capture what it looks like. I'll try again with a different camera.
   / Insulation for shop ceiling #65
I added 2 inches to the length of each panel from the exact measurement so I had about 4 inch overlap.
   / Insulation for shop ceiling #66
Correction, I meant 2 inches on each end to get the 4 inch overlap. Instead of regular pole barn screws, I used a stainless screw with a countersink type profile. That was what the metal supplier recommended.
   / Insulation for shop ceiling #67
I thought pole barn screws were expensive! Almost free in comparison to stainless screws aren't they? And I don't understand the "countersink"...the metal (liner or thicker building) is not that thick. What can possibly be holding up your metal if you countersink it? I think I'd stick with the standard pole-barn screws...that rubber washer is there for a reason.
   / Insulation for shop ceiling #68
I just bought self drilling screws from Fastenall, no rubber washer. In hindsight I think the rubber washer screws would work better to minimize distortion of the metal and still get a tight fit. Not sure about the cost difference.
I used a Dewalt 18V cordless 1/4" impact driver to install mine. Worked great and only overtightened if you let it bang a few times.
   / Insulation for shop ceiling #69
That "dent" method I learned from my builder worked great...stack several sheets, measure the top sheet (rafter spacing along the length and next to each major rib on the width) and give it a "whack" with a center punch. Those dents show the screw locations and you don't have chalk lines or a lot of pencil marks to clean-up. Probably not a big problem on the interior but drilling was a "no-no" because it leads to premature rusting. When the dents start to get faint, insert new sheets under the pile and give it another series of whacks. Ceiling work is definitely a 2 person job and scaffolding would be a big help as would "dean man" supports. Panels aren't heavy but they can be awkward to handle (you don't want to buckle them). I let my builder to it and he flew through it using a homemade scaffold that OSHA would have had a fit over but he had been doing pole-barns for decades.
   / Insulation for shop ceiling #70
I did all of mine alone. Well,,,, me and my drywall lift..... Best part about the lift was that it would stand there holding that panel all day and never complain or get tired. Even if I never use it again it more than paid for itself in labor cost savings alone. :)
VOLVO L45G RUBBER TIRE LOADER (A51242)
VOLVO L45G RUBBER...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
Case 830 Tractor (A50514)
Case 830 Tractor...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
INTERNATIONAL 5100 (21) ROW SEEDER (A51243)
INTERNATIONAL 5100...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
