international TD 6
   / international TD 6 #1
Hookblock
WI
JD 4310
I was wondering if anybody had away to id a TD 6. The tag by the foot brake pedal is gone. Thanks
   / international TD 6 #2
Any idea of age? A TD9 mid '40's the serial # was stamped upper left side of dash.This was the only ID I knew about.
If gas/Diesel conversion engine hope you never have to hand crank.
ken
Ken, not Shur of the year, it is a gas/ diesel. Been sitting for years, just got it to run on gas. Was going to look into a service Manuel for it.
   / international TD 6 #4
The engine and much of the drives are the same as the old MD, WD-6 farm tractors.
   / international TD 6 #5
Hookblock have a manuel for the TD9 and part # may be different but the whole concept is the same. engine adjustments and when to adjust.
Printed in 1944 and used into the 70's never really looked at the dozer size. Not like today where every tractor # has special parts.
Send a pm of address will mail to you. I will never use again.
ken
Thanks Ken, sent you a pm
   / international TD 6 #7
Hookblock Was up Hwy 39 toward Baraboo/Dekora and the Wisconsin Dells this spring.
Then next week going to Rockford/Belvidere Ill guess not far from your location. Book will be mailed tomorrow should be at your address by end of week. enjoy.
Is this dozer for work or yard ornament?
ken
Ken, Thanks again. I plan on using it for small projects around the house and up in the woods. I like it because it is portable for me. As a plus it also has a pto, now looking it finding a tph for it so I can use it more. :D
Got some pics, and my first dirt :D
   / international TD 6 #10
Hookblock Good pictures and the tractor looks hardly been used. Also the method of raising the blade is standred. Really it is a good looking dozer for the age.
Trust the book will help in getting repaired and enjoy the use of it.
Headed for Belvidere Ill. in the morning going to the fair grounds Holstein cattle show.
ken
   / international TD 6 #12
I tried to post the TD6 manuel that I have but the file is to big to post any suggestions how to post?
   / international TD 6 #13
Looks like the Drott blade package on it? Mine has the BE.
The T6 series is an amazing piece. Ours still runs great, engine parts are pretty easy to source - same as a farmall M normally.
Cummins 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
14C SCRAPER (A58214)
