Snow Is adding max weight to a Grand L a good idea.
   / Is adding max weight to a Grand L a good idea. #1
utvol2003
Blountville, TN
Kubota/ L6060
I posted this on the Orange Tractor Talk forum wanted to get a little more insight.
I would like to know if anyone has had any bad experiences with filled tires and backhoe work on a grand L? I am having my L6060 built now with filled R1-14.9-26 tires, 600 lbs of wheel weight, Backhoe, and a 4n1 loader. All I have heard is how Kubota tractors are light and need more weight, but can the axles in the front and rear handle the added weight? I will continue to search the sites for answers.When I opened this thread I hoped to get some advice from those with real world experience. My concerns about weight began with operating the tractor on and around hills. The area will be very difficult to maneuver around and thought more weight would give me more stability. The next thing was using 5.5ft disc mower and baler (still unsure of baler size or type). I plan on building a 1/2 mile or so of gravel road across a steep incline. Then there is the fence installation with an auger and a 6" post driver. Any advice is greatly appreciated!
   / Is adding max weight to a Grand L a good idea. #2
Hi,
Just to start things off, weight in the tires, or as wheel weights, is different than weight added to the tractor itself. This added weight is not generally carried by the axles, since it is resting on the ground.
Naturally, if you do something that causes a wheel to lift off the ground then the weight of the tire IS carried by the axle, but the weight of the tractor IS REMOVED from the axle, so there is likely a net reduction in the weight felt by the axle.
So it seems to me you should not have to worry about loading your tires or using wheel weights.
Bill
   / Is adding max weight to a Grand L a good idea. #3
I would like to know if anyone has had any bad experiences with filled tires and backhoe work on a grand L? I am having my L6060 built now with filled R1-14.9-26 tires, 600 lbs of wheel weight, and a 4n1 loader. All I have heard is how Kubota tractors are light and need more weight, but can the axles in the front and rear handle the added weight? I will continue to search the sites for answers.When I opened this thread I hoped to get some advice from those with real world experience. My concerns about weight began with operating the tractor on and around hills. The area will be very difficult to maneuver around and thought more weight would give me more stability. The next thing was using 5.5ft disc mower and baler (still unsure of baler size or type). I plan on building a 1/2 mile or so of gravel road across a steep incline. Then there is the fence installation with an auger and a 6" post driver. Any advice is greatly appreciated!
I have a very similar MX4800 with Rimgard loaded R4s PLUS cast-iron wheel weights. I use it with a Woods BH90x hoe (very similar to a Kubota BH92).
It has about 420hrs on it. Maybe 50 of those are digging with the hoe. No problems so far. I wouldn't be caught on my MX4800 without loaded rears (unless the FEL was off).
Obviously, the stabilizers are down when digging. The 3pt can lift north of 2tons and the rear end has to be designed to support that so the hoe transport weight doesn't worry me.
You may already know this but Kubota's engineers appear to be very conservative. So the warning in the manual about loaded rears and BH use is an example of this (IMO).
I don't recall ever reading on TBN of rear axle issue due to weight stress. I do recall several Century/Branson's with issues.
You could put a massive stack of wheel weights on and skip loading the tires if you were worried. You could then take off the weights when the BH was on. (hint: you won't actually take off the weights because they are indeed heavy and it's kind of a PITA)
   / Is adding max weight to a Grand L a good idea. #4
The Grand L tractors have adjustable rear wheel widths. One of the nice features justifying Grand L elevated price. There are four widths available on the four larger Grand Ls with R1 tires, from 50" to 56" and three widths with R4 tires, from 52" to 59". (This info is in Operator's Manual.)
Did you configure your L6060 for optimal wheel width when it was assembled at your dealer?
I would make sure you have optimal rear wheel width installed before messing with anything else. Rear tires filled 3/4 with liquid will certainly lower tractor center of gravity but probably will not increase hillside stability as much as wide rear wheels. On hills, bear in mind that load on axle will not be symmetrical. Load on downhill wheels and downhill side of axle could be 75% of total axle load.
If I interpret your opening post correctly, you are considering 600 pounds of wheel weights too. Wheel weights seem unnecessary and potentially stressful to your rear axle on slopes.
If you paragraph your posts they would be easier to interpret. Your opening post contains three paragraphs waiting recognition.
   / Is adding max weight to a Grand L a good idea. #5
I've got two Grand Ls. Started out with a GL4200. I would say you won't have any issues at all. If you want to talk weight on a real axle I put a 8 foot Rhino TW96 on my G4200 and would ride around over this rough pot holey farm with it in the air on a three point mount. You can bet the shock weight on those axles were off the charts when I would be buzzing along with that very heavy mower on the axles and hit a ground hog hole. One time it bounced me up in the air a bit. Never a axle issue. I've got a 900 pound tiller on my GL5040 and carry it over the same rough ground bouncing along and never give my axles a second thought. That three point weight IS on the axles not like the weight on the tires which isn't.
I kinda like Kubota's idea of a light tractor but one you can add weight to if you need it. I've got a M7040 with larger tires and cast wheels. 1800 pound Land Pride 3696 mower on a three point mount. Tires Filled with fluid. Add on a loader and bucket , not to mention me <cough> and that thing is pretty darn heavy.
   / Is adding max weight to a Grand L a good idea. #6
I'm betting, when over loading, you would have front end or front axle problems before you will have rear axle problems!
SR
   / Is adding max weight to a Grand L a good idea. #7
Something to keep in mind is tire load capacity. I believe your 14.9 x 26 R1 tires have a 3,000 pound load rating vs 4400 pound rating on a typical 17.5 x 24 R4 tire. Tire companies state that liquid ballast must be included in the load. Not sure what your weight might be with loaded tires and backhoe. I've typically seen backhoe on R4 equipped tractors due to the higher load capacity. There are many caveats in the load inflation tables. For instance while stationary the tire can be overloaded to 135% overload (235% of rating). At 2.5 mph that drops to 100% overload and continues to drop to rated capacity at standard speed (20 mph).
   / Is adding max weight to a Grand L a good idea. #8
I have a L4060, same frame as the L6060, just with less HP & smaller tires... I can spin the tires on mine easily even with loaded rears. You'll definately need lots of ballast to put the extra power down with the extra HP. The stability on my L4060 is way better than my old L3200, no way i'd go back or roll without ballasted rears.
Thanks Jeff for the great information!
The tractor is still at the dealership (Over 2 weeks now, after a waiting over 2 months on delivery) This has given me way to much time to second guess the set-up. The wheels are set at their widest setting and the wheel weights are supposed to be installed before delivery.
I read the info from MHarryE (great info for a beginner like myself) on the load rating of R4 vs. R1 tires and I was intrigued, but not surprised. I need the AG's to maneuver the hills safely. I realize I'm asking this tractor to do a little more than should be required, but I truly believe the L6060 will give me the best chance to succeed.
Good call on the post. I sent the post from my I-phone in 3 paragraphs. I may need to log-on to my computer before my next long post. Thanks Again!
   / Is adding max weight to a Grand L a good idea. #10
What are you asking the tractor to do? I'm curious what you are going to do to stress the tractor.
For hills the rear wheels need spaced out as far as possible. Also fluid in rear tires will give tractor lowest center of gravity... fill 3/4 up.
Steel Square Fuel Tank (A57454)
Steel Square Fuel...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
