Is the 62D deck a floating or ground contact deck?
   / Is the 62D deck a floating or ground contact deck? #11
I've been wondering why Deere removed the stow-and-go brackets from the more recent 62D decks. Someone suggested it was a cost cutting move, but I can't imagine that Deere would do that when they hyped it as a feature in all the videos and sales literature.
Yep, I was fooled on this one.....all the sales literature and videos showed the Stow and Go feature on the 62D MMM deck.
I'm still steaming too! Since I spoke with my JD sales guy BEFORE purchasing the tractor about the Stow and Go feature which was the PRIME reason I also purchased the iMatch Quickhitch.... ! The salesman either didn't put two and two together or failed to inform me that the Stow and Go feature on the 62D deck was no longer available. :mad:
You should have seen my face when the tractor arrived without the Stow and Go brackets... :mur:
   / Is the 62D deck a floating or ground contact deck? #12
For the spray/wash attachment to work properly it is important that the deck is lowered all the way to level ground with the wheels released from any setting. Does a great job if used regularly, othwise the grass will dry hard as a rock and stick making it impossible for the water spray to easily remove. I use it after every mowing which results in absolutley no grass under the deck. Takes me 5 to 10 min to complete and well worth it.
   / Is the 62D deck a floating or ground contact deck? #13
Hammsman I beleive you, but wonder why the deck needs to be all the way down to use the spray/wash?
It is surprising that there is no mention os the spray/wash in the owners manual.
Thanks, Hammsman. Any other tips? Do you just connect a garden hose to the port and then turn on the faucet while the mower is running at PTO speed?
   / Is the 62D deck a floating or ground contact deck? #15
Agree with Hammsman, the deck has to be lowerded to the ground, turn water to max and run at PTO speed. :thumbsup:
   / Is the 62D deck a floating or ground contact deck? #16
Agree with Hammsman, the deck has to be lowered to the ground, turn water to max and run at PTO speed. :thumbsup:
Thanks - didn't know about the need to lower the deck to the ground and the speed - PTO... will give it a try! :)
I still need to figure a way to haul the deck around with my 3 point, since I have no Stow and Go brackets....
BTW - I get a great cut with this deck on my 10,000 square foot lawn after I adjusted the blade height per the manual. From the dealer, the mower was not correctly height adjusted. Bought one of those blade height gizmo's er gauges and the cut is now precise, left to right, fore to aft. Also have the mulching kit installed which works like a charm. I have an acre and a half of field grass that I also mow with this deck, but in the full up position.
   / Is the 62D deck a floating or ground contact deck? #17
I have the same deck on my 2320. Even with the 2320, one has to buy the optional lift kit to use the console dial for cutting height adjustment. I decided to use the rockshaft lift mechanism that is used on the 2520 and 2720 and save the money. It took a good while for me to get the deck set such that it cut well. Now I run my gauge wheels pretty low such that they contact the ground if it is irregular but still do not bear the weight of the mower (since they are lightweight plastic they will not hold up to that). I run them a notch lower than stated in the manual one should. I also leveled my three point and placed an additional jam nut on the left to prevent it going out of true. Though it should not affect the cutting deck, it does if this is not aligned. I set my rockshaft stop such that I cut my folks' grass at about 3.5 inches, which leaves a really good cut on their lawn now. My only problem is that the tractor is so heavy (loaded tires and weights) that it tends to indent the ground so I choose different patterns each time. I have found the water nozzle feature VERY helpful so far, but I do not like to mow wet grass so I use it about every third time. My mower must have been an earlier production one as it has the lift latches for positioning. I know I am going to get some disagreement on this, but I have been happy with my 2320 mowing and I cannot see mowing a finish lawn with anything larger than one of the 2000 (2305, 2320, 2520, 2720) series tractors and not risk substantial ground compaction. I loved my 3720 but when mowing it compressed the ground like, well, a car--which was essentially what it was in regard to weight. Overall I have been happy with my 62d mower deck, but I do not feel it cuts as well as a high end Frontier, Woods or Befco RFM. I would have done that route had my folks' place (where I mow primarily) not had so many tight areas where that swinging deck would have tagged trees, buildings, etc.
John M
   / Is the 62D deck a floating or ground contact deck? #18
..We'll I'll need to try this, but I think the 62D deck on the 2520 is physically too large to be pulled out sideways from under the tractor. Also, the rear anti-scalp wheels are fixed (as opposed to castered) and which will require more effort.
You've got me at a disadvantage there . I'm not familiar with the deck
layout ( front to back measurement , attaching points ) but I'd be interested to know if
you could save yourself trouble , if it worked out .
   / Is the 62D deck a floating or ground contact deck? #19
You've got me at a disadvantage there . I'm not familiar with the deck layout ( front to back measurement , attaching points ) but I'd be interested to know if you could save yourself trouble , if it worked out .
I haven't had time to check out the 62D deck slide out removal procedure on my 2520... but I'll post when I have the opportunity.... It would be great if I can physically slide the mower deck out from under the tractor without having to drive over it...
   / Is the 62D deck a floating or ground contact deck? #20
Hmmf, not sure I totally understand your note, but let me try.
What you're saying is why not pull (er push) the mower deck out from under the tractor from the side, instead of driving over it for removal/installation. If the deck is not driven over for installation and removal, then the anti-scalp wheel pins do not need to be released.
Well, today I finally had the opportunity to remove the 62D deck from my 2520, and I tried pulling it out sideways on its wheels... but it will not clear the front and rear wheels.
So the only way to remove the 62D deck from a 2520 is to drive over the deck. Again, this means lowering the deck to the ground... and yes, oh my aching back, lifting the deck afterward so I can extend the wheels to move the deck to its storage location.. I sure miss the Stow and Go feature.. :(
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
2018 Deere 323E (A53317)
2018 Deere 323E...
Trailer (A59231)
Trailer (A59231)
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
