Is this a fuel scre
   / Is this a fuel scre #1
1971bmw2002
ym146
Is this a fuel adjustment screw and if so how do I make it to where more fuel goes in? Yanmar ym 146
   / Is this a fuel scre #2
   / Is this a fuel scre #4
Jeez... good luck with that, based on the information given! Maybe a zoom out on the area where that photo was taken? The YM146 isn't exactly the most common tractor here, today.
Anyone remember when magazines used to post extreme close-up images of common daily objects, to see if readers could guess their origin?
   / Is this a fuel scre #5
The Ym1100 is the closest. Inj.pump & fuel should be the same. YM1100, 2Cyl. 3.26L. 14Hp.. The YM146 2Cyl. 3.8L 14Hp.
Limited for sure and I believe the Inj. Pump IP-200 should be correct. YM1100-1500 2Cyl. use it also. ?
   / Is this a fuel scre #7
These pages are not for that exact engine but they should help describe what that limiter screw does. Keep careful track of how much you turn it so you can go back to where you started if things don't work the way you wanted. I have seen people tinker with that governor and then never be able to get the engine to run right again.
Aaron
   / Is this a fuel scre #8
Aaron
Another good method if there is room, place a steel scale in millimeters from the base surface to the bottom of the nut. Record the spacing value. Then you can return to the same position as before. If you are really picky, a vernier caliper can be used for being spot on.
Wood Native American Statue (A56859)
Wood Native...
Leer Camper Shell (A57454)
Leer Camper Shell...
2017 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52709)
2017 CATERPILLAR...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Year: 2013 Make: Ford Model: Focus Vehicle Type: Passenger Car Mileage: 83,831 Plate: Body Type: 4 (A59231)
Year: 2013 Make...
