Is this a fuel scre
   / Is this a fuel scre #1
1971bmw2002
ym146
Is this a fuel adjustment screw and if so how do I make it to where more fuel goes in? Yanmar ym 146
   / Is this a fuel scre #2
   / Is this a fuel scre #3
Looks more like an oil drain to me.
   / Is this a fuel scre #4
Jeez... good luck with that, based on the information given! Maybe a zoom out on the area where that photo was taken? The YM146 isn't exactly the most common tractor here, today.
Anyone remember when magazines used to post extreme close-up images of common daily objects, to see if readers could guess their origin?
   / Is this a fuel scre #5
The Ym1100 is the closest. Inj.pump & fuel should be the same. YM1100, 2Cyl. 3.26L. 14Hp.. The YM146 2Cyl. 3.8L 14Hp.
Limited for sure and I believe the Inj. Pump IP-200 should be correct. YM1100-1500 2Cyl. use it also. ?
   / Is this a fuel scre #7
These pages are not for that exact engine but they should help describe what that limiter screw does. Keep careful track of how much you turn it so you can go back to where you started if things don't work the way you wanted. I have seen people tinker with that governor and then never be able to get the engine to run right again.
Aaron
   / Is this a fuel scre #8
Aaron
Another good method if there is room, place a steel scale in millimeters from the base surface to the bottom of the nut. Record the spacing value. Then you can return to the same position as before. If you are really picky, a vernier caliper can be used for being spot on.
UNUSED FUTURE D-PDQ 45" LAND LEVELER (A58376)
UNUSED FUTURE...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
(2) BKT TR-387 TIRES (A58376)
(2) BKT TR-387...
UNUSED WHEELED SKID STEER AR500 3/8" STEEL (A58376)
UNUSED WHEELED...
UNUSED JCT 72" HYD BRUSH CUTTER (A58376)
UNUSED JCT 72" HYD...
2018 Bobcat S570 Skid Steer (A59213)
2018 Bobcat S570...
