JD 2520 vs Kubota B2620 in Resale
   / JD 2520 vs Kubota B2620 in Resale #1
Seezer
I'm looking to buy a 4WD tractor to landscape my house - just can't stomach paying $70-100K to a landscaper. Figure I can landscape for $20K in materials + the tractor cost over a year (and quite a bit of my time). I'm looking at the Kubota B2620 w/FEL and JD 2520 w/FEL. I would plan to rent implements (scraper, tiller, etc.) as needed and have a friend with a 790 Deere with backhoe so I don't feel the need to spend the extra $ for just 1-2 uses. Both are fairly identical in specs - I can get the Kubota for $15,250+ tax and the JD for $15,940+ tax. Both have good financing. Can anyone comment on major pros/cons that would sway the decision in one direction? For me, the key will be resale. Will the resale on the JD 2520 be higher than the Kubota to justify the higher price? Also, what amount of depreciation should I expect after a year, assuming low hours (<100 hrs), garage kept, clean, etc.? I'm hearing 10-15%. Thanks!
   / JD 2520 vs Kubota B2620 in Resale #2
How much property do you have? If it is more than 5 acres you'll probably end up keeping the tractor. Pick the one you like best, from a dealer you are comfortable with. Why not buy used?
I wish I had 5 acres... I actually have .6 acres and a strict HOA in terms of what must be planted - grass, shrubs, stone, etc. I have been looking for used, but have not been able to find anything here in Colorado that meets my needs. With the financing deals and having a warranty, it makes a new tractor seem ideal. Since I will sell the tractor when finished next Spring (and buy a zero-turn walk behind mower), not mow/maintain my property with it, and have limited garage space I am really focused on resale. Both tractors are solid and will meet my needs for hauling stone, cobble, dirt, sand, pavers, compost as well as tilling/scraping. Thanks for any help you can provide.
   / JD 2520 vs Kubota B2620 in Resale #4
I would have to say you would take a lesser hit on resale, if any at all, buying used. You'll probably sell a used one for what you paid. You will more than likely take a big hit on selling a slightly used tractor especially owning it for such a short period of time and you'll need to sell it at a reduced price (not really what it's worth) so a buyer does not want to buy new. Seems if you cannot find a used tractor regardless of your decision you wont have any problems selling either one.
   / JD 2520 vs Kubota B2620 in Resale #5
The Kubota price seems high. I saw one at a local dealer for $14,000.
Will
   / JD 2520 vs Kubota B2620 in Resale #6
IMHO, and it's just that...The JD will hold it's value better. I know I am going to get in trouble for saying it...flame-suit ON:D
   / JD 2520 vs Kubota B2620 in Resale #7
I would have to agree, but I did not say it first. Good luck with that.
   / JD 2520 vs Kubota B2620 in Resale #8
I like Kubota's, but having said that I do think that the JD2520 is more tractor than a B2620. 2K more money around here too. In engine size, etc. the B2620 is closer to the JD2320, and closer in capabilities too. If I were doing landscaping I would prefer the position control on the JD. Resale will depend on area preferences, but perhaps with an edge to the JD.
Great feedback. I'm surprised the Kubota is closer to $14K in the East. I really expected the price difference between the JD 2520 and Kubota 2620 to be closer to $2K, so I never really considered the Deere at first. Maybe that is why the 2520 only looks $700 higher - the Kubota is too high here locally. On paper, the two tractors appear to be almost identical, but I did notice the tires are much larger on the JD 2520 - the tractor just seems bigger overall. Can I ask - what is "position control"? I've seen this mentioned but do not know what benefits it provides. Thanks again for all of the great feedback. Unless I get lucky and find a used 2520 locally, I may be leaning in the direction of the Deere based on everyone's feedback and the better 42 month/$0 down financing from John Deere.
   / JD 2520 vs Kubota B2620 in Resale #10
I can't explain all the mechanics of position control but I can break it down for you a bit. Regular 3 point hitch control is a lever that controls a hydraulic valve. It works like your loader...you push the lever forward and it (3 Pt) goes down until it either bottoms out or until you stop holding the lever forward. Wherever it stops it stops. Same in the up position. With the position control, you have a lever that you pull or push and the lever stays wherever you leave it (i.e. it does not return to the neutral or stopped position). There are markings on the slot that the lever travels through, marked 0 through 9 for example, 9 being full height, zero being bottomed out. Wherever you set the lever to, the hitch will go to a height that correlates to that number. Now, the number itself doesn't signify an actual value (i.e. setting 5 doesn't equal 5" of height or 5' of height), it's more along the lines of, you're dragging a box blade, you start cutting dirt with it and you realize that setting 2 gives you the exact height you want, so on each pass, if you set the lever to setting 2, you'll always set the 3 point to the same height. Without position control, it is all guesswork.
Hope that makes sense, that's probably a bit wordy for such a simple thing.
2007 Volvo VHD Tri-Axle Prentice 2124 Forestry Grapple Truck (A44571)
2007 Volvo VHD...
2010 Crown Victoria Sedan (A44572)
2010 Crown...
Kubota L4740 (A46443)
AGT 40' Shipping Container (A47809)
AGT 40' Shipping...
Graco ThermoLazer Thermoplastic Line Striper (A44571)
Graco ThermoLazer...
2014 Ford E-150 Cargo Van (A44571)
2014 Ford E-150...
