JD 4710
   / JD 4710 #1
freedy
Hi, I'm looking at a JD 4710 power, reverser trans & 460 loader with 525 hrs.
Good or bad choice? Vertical exhaust can you buy one from john deere?
I DO NOT understand why manfacturers insist on exhausting carcinogens into my lungs!!
   / JD 4710 #2
Good or bad choice?
That depends on your intended use and the price of the tractor.
   / JD 4710 #3
At one time it was offered but not sure now.
   / JD 4710 #4
Yes you can still get a vertical exthaust for your 4710. go to jdparts.com you can look up parts so you have the numbers you need when you go to the dealer. The kit your looking for is kit # LVB250013 you will need to cut a part of your hood they give you a template in the kit.
   / JD 4710
Thanks for all the help. This is truly the best website.
   / JD 4710 #6
Hi, freedy,
I have a 4610, the next size down, with an ehydro transmission and about 415 hours on it. Have the 460 loader. The tractor is absolutely bullet proof, and I use it hard. Only regret is I didn't get the 4710 with a little more power. The ehydro really sucks the power away from the PTO. I was considering trading up to a 20-series, but the Yanmar engines in the older 10-series are known quantities, and I've heard there are some teething problems with the new JD turbo engines in the 20s.
Good luck with your purchase.
Service Truck (A59230)
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON ESP...
