JD X310 - no spark
   / JD X310 - no spark #1
ricardo1967
Columbus, IN
2012 JD X310
First time posting, long time reader. Problem at hand: JD X310 cranks, but no spark. Details:
1) 2012 JD X310 bought in Jan/2016 from first owner - in great shape - with ~140 hours.
2) I got carried away while power washing it a couple months ago (using Krud Kutter multi-purpose pressure washer concentrate). Idiotic, I know.
3) While power washing, some water/detergent reached electric components, causing it to self-crank randomly. In panic, immediately suspected it was the ignition switch, so I disconnected the battery.
4) The mower worked fine in the following weeks. I'd disconnect the battery after using it, just to be safe and avoid unintended cranking. After a couple weeks, I got confident and stopped disconnecting the battery. That worked fine for a month or so.
5) Than one day I find the mower in the shed with battery totally drained. So I jump started it to go mowing. It fired up fine, worked for 10 minutes, did a loud back fire and died. It smelled burned plastic (wire or something). It wouldn't crank, all dead. All fuses were good.
6) I found the micro-relay (JD info is confusing, it's either PN 57M9880 or M169838 they're equivalent) visibly burned. I replaced the relay with a generic one (Carquest BWD R4823). This restored cranking, but still no spark.
Model: X310 Tractor
Date of Manufacture: 050212
Product Identification Number: 1M0X310AECM223815
Engine: Kawasaki 603
Family: KAXS.603N4CB
Made of Mgf: 0412
Code: FS600V-AS21-R
E/No: FS600VA43163
Any tip on where to start troubleshooting it? Thanks in advance.
Here is a location for the FS600V engine shop manual.
Down load and save. Look in there for some hints on where to start troubleshoot.
Richard
Richard, thanks a lot for the engine shop manual, good stuff!
   / JD X310 - no spark #4
Not that this is your problem but when the ECU fails you can crank all day and no sparky. At around $73 it worth troubleshooting a little bit though, p/n am141075 (it is a little rectangular box that mounts under the dash).
Thanks for the tip Morrison... however, I could not locate this ECU in my X310. Is it miniscule and integrated with the hour-meter?
I'm a new member here and can't post pictures yet.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Deere 35P (A53317)
Deere 35P (A53317)
Toro z turn (A56859)
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
