OP
dirtworksequip
Veteran Member
- Joined
- Jun 3, 2006
- Messages
- 1,463
- Location
- Wheeling, WV
- Tractor
- 2006 JD 3520 w/cab & 300CX loader. 1995 JD 870 w/440 loader & 8b backhoe.JD 455 w/54" mower deck.
AKfish, yes I contacted the dealer to get their guess on how much labor would be involved IF the frame was bent. Their service manager figured it might be around 50 hours @ $65. per hour to do the frame change if needed. Also checked on having the dealer move the machine from my place to their shop. Transportation was between $90 and $100 one way.
I have taken measurements at several different points and locations and tried to eyeball to see if I can see anything else that might be out of wack. Its hard to find a place where you can get a measurement from the same points between the right and left sides of the tractor.
Yesterday I put my 300cx loader on to see if every thing was ok there. It seem like everything was ok as far as the loader, although there is quite a bit of flex in the loader and I'm not sure even though it went on ok that is an indication that everything is still straight. I have looked at the tires and wheels and I know what everyone is saying about how they look in the pics. I put a level on both the fronts and rears and they do seem to be about the same, but thats still not saying that they are ok either.
I also went ahead and replaced the broken draft link and reinstalled the landscape rake, as there was about 3 inches of snow here today. I ran the tractor about 4 hours using the rake and front loader to do some snow removal. I didn't realize how efficient the front blade was at removing snow compared to using the front loader. I absolutely hated using the front loader for cleaning several driveways that I do for some elderly people. Its just twice as fast to do with the front blade. Maybe I ought to try and put the mangled blade back on the tractor. Everything still works its just all off center now.
I called the adjuster and he said he had contacted the Deere dealer that I deal with and was getting together a parts list thru the dealer. I then called the dealer and their parts guy said he was trying to get together a parts list for the damages between customers. I email both the adjuster and the dealer parts man the list I came up with. I guess now I'll just have to wait and see what the insurance company comes up with.
Thanks again for all the input and advice.
Sincerely, Dirt
Sincerely, Dirt
