JD4110 strg ball n sockets worn out. Need some mod links
   / JD4110 strg ball n sockets worn out. Need some mod links #1
2001 JD4110
Wheatland,NY
JD-4110
I somehow stumbled onto a couple good ones the other day?? I need to do mine.
Does anyone know the Napa tie rod ends/brands I might ask for? The tie rod link holes are 13.7mm at bottom & 10.45mm at the top approx. The other thing too...is there a choice of having the new t-rod welded to link/bar OR welding a "threaded sleeve" to link/bar for future replacement and or adjustment:)?
   / JD4110 strg ball n sockets worn out. Need some mod links #3
I got this for my JD4300 at a Napa. Moog.
They have a large book that shows Moog sizes.
I did have to drill and tap it, however.
What's the part number on that? and..so you did both sides of the bar-& you drilled & tapped the oem bar across the front & made it adjustable? Also, I want to do the one at the end of the p/s ram-rod....
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
1770 (A58375)
1770 (A58375)
2019 Caterpillar 259D Compact Track Loader Skid Steer (A60460)
2019 Caterpillar...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
Zero Turn Mower (A59231)
Zero Turn Mower...
