Comparison JD4110 versus Kubota B7500
   / JD4110 versus Kubota B7500
I just bought a B7500 with FEL and BH. I on the other hand decided to keep my JD325 to mow the lawn with. If I had tried to use the 7500 on my yard, it would have really tore it up because of the moisture. If I waited until it was dry enough to mow with the 7500, well I still wouldn't have cut my grass this year.
   / JD4110 versus Kubota B7500 #22
I think it all depends on your application. For me, I could never mow my lawn with the B7500. I have a JD LX277 that does a great job. The B7500 would make a mess out of my lawn with the R4's and moisture we have in the NW. I also have used the lawn tractor with a trailer as a "dump truck" when using my backhoe. It's nice to have both.
Greg
Thanks for the info everyone. I certainly have more food for thought.
At this rate, when I finally make my final decision on the tractor, I will be armed with total knowledge....., well, maybe not total knowledge, /forums/images/graemlins/wink.gif, but certainly more knowledge than I had before.
Garick
   / JD4110 versus Kubota B7500 #24
Garick.
KEEP THE LAWN TRACTOR as long as it performs to your satisfaction. It will be kinder to wet turf than the B7500. My CFO does the lawn cutting and I do the rough stuff. Without that lawn tractor, I would have to maintain the lawn which would cut into my fun stuff. I hate cutting the lawn. Would rather play in the soil. Its a win-win situation /forums/images/graemlins/smile.gif.
Ken
Is the Kubota b7500 similar to a BX22 Kubota, I am shopping for a new tractor and haven't really nailed it down yet.I would like a backhoe and I would like a bigger tractor.Is the B7800 tractor a lot larger and harder to maneuver. I like the horsepower, the three point hitch lift. and the loader lift.
   / JD4110 versus Kubota B7500 #26
You came to the right place to find out all the little differences in tractors. You will get more response if you ask the question on a new thread. If you like Kubota it would be best started in that forum. I am new and learning so I will leave the opinions to the rest of the group. It is fun learning together.
   / JD4110 versus Kubota B7500 #27
David, the B7500 is a compact tractor as opposed to the BX-22 sub-compact class. The BX22 does have a backhoe however. You can get a backhoe for the B7500 if needed. The B7800 is in the largest class of compacts and will cost a bit more. In order to get the best advice from these very knowledgable folks, you need to tell us what you plan to do with a tractor /forums/images/graemlins/smile.gif.
Ken
   / JD4110 versus Kubota B7500 #28
Have you checked out the KIOTI LB1914 or the CK 20 yet?
I just ordered the LB1914. Should be here soon and I'm chewing at the bit to give it heck /forums/images/graemlins/smile.gif
13,200 = 54"loader w/tooth bar, 5' finish mower and 55" tiller.
2007 POLAR TANK CRUDE TRAILER (A55745)
2007 POLAR TANK...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2016 Ford F-450 Flatbed Utility Service Truck (A55788)
2016 Ford F-450...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A55788)
2012 Ford F-550...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
