I called Ken at Asian Tractor Parts in Ontario to order gaskets and oil pump. I still wasn't settled on what was wrong cause two major problems at same time can't be coincidence but I couldn't figure it To his credit he didn't just sell me the pump. He suggested the same as quicksand farmer - check the valve train first
Just done that The cam shaft is broke. Cylinders 1 and 2 are strong. Cylinder 3 valves are both closed but low compression is leaking into 4. Valves on 4 are partially closed and don't move. No compression on 4
My guess is that cam broke but fuel keeps dumping into 3 and 4. Pressure builds in 3 and blew head gasket between 3 and 4. Water and unburned fuel up the stack as white smoke but engine started and ran on 2 cylinders. I'll confirm tomorrow night when I remove head
The splitting manual is very good. I was unaware of it. I need to split to get oil pan off so I can remove oil pump so I can pull cam.
While I'm this deep inside, I'm wondering if I should pull all the pistons, sleeves, rings, etc and measure specs on everything and make sure it is assembled correctly I've already done major work on the timing gears because a bolt fell out and now this.
Thanks for being a good sounding board
