John Deere 2350 tractor under powered PTO need info on hydraulics on this
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #41
I am not familiar with the break away coupler shown in picture 2. Maybe TxJim is?
Does lever at the top (#12) in parts drawing have to be moved? Possibly 90 degrees to allow flow from the coupler?
TxJim, Have you seen this post? Do you know what lever 12 does? How it should be for flow?
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #42
I thought I answered your question on that post. Lever 12 is used by moving to the left & right to connect/disconnect couplings while under pressure. Lever should center by itself and not affect flow of oil.
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #43
Correction. The 2000 series 2.4 cu" 23.3 gpm pump was optional upgrade from the 1.4cu" 13.5gpm 1000 series pump.
   / John Deere 2350 tractor under powered PTO need info on hydraulics on this #44
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
Blue Diamond 103709 (A53317)
Blue Diamond...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
