John deere 301 pto lever stuck engaged
   / John deere 301 pto lever stuck engaged #11
I think after RS housing has been removed trans gears & shafts will block access to pto engagement collar
Just a follow up if anyone is having the same issue. I had this serviced at a local shop while I was deployed and they said it was:
The pto shifter had been pushed forward to far and came out of the bracket it rides in. they set it back in and recommended we build a bracket from the floor board to prevent the shifter from moving that far forward. They said if it does come out, it can sometimes be put back in immediately but the catch mechanism can slide forward preventing it from reingageing. No parts replaced, except for gaskets. They removed the rockshaft housing and put the shifter mechanism back in place.
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
2013 Kubota RTV-X900 4x4 Diesel Utility Cart (A55787)
2013 Kubota...
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
205113 (A52706)
205113 (A52706)
