John Deere and Yanmar
   / John Deere and Yanmar #61
The seat and mower lift are two of the complaints I have on my JD 2305. I have on occasion hauled my Kubota to our other farm where we have the 2305 so I won't have to use it.
That goes both ways. My nephew came over and used my Deere after using his friends Kubota. He said the Deere was tighter, easier to use and a much better overall tractor.
Personally I prefer the Deere HST and reverse set up much more than the Kubota and I think the fit and finish is better too.
   / John Deere and Yanmar #62
Yeah, I have said before my preference for the Kubota is mostly a personal one as I bought my Kubota after owning the JD for a little over a year and was going to replace my BX2200. I replaced a JD425 with the 2305, so I was use to the HST operation. In using the 2305, I find the seat to be uncomfortable to me though my wife has no problem; sets too low in the back. I have also been unable to get use to the brake on the left and really don't like the flimsy feel of the throttle or FEL control, but have not yet had a problem with them. I have mentioned the height control has never worked properly and that has been mentioned by other 2305 owners.
When I brought the Kubota home my wife hated the HST controls until she used it and now loves it.
Maybe my Kubota is unique, but I challenge anyone to crawl onto, around and under both machines, 2305 and 2660, and show me any superiority in JD quality. One thing that impressed me is that the deck belt on the Kubota is roughly twice the width of the JD, but I have had good service out of both, so whether the thicker belt is significant or not I can't say.
Something I have noticed is that for a while Kubota replaced some metal body parts with plastic, but after complaints returned to more metal. Both tractors use too much plastic for me.
In the end my preference for Kubotas is based on what fits me and my needs best and not due to lack of quality in JD and I can only speak about these two models as I may very well prefer a JD in a different size. I guess that is why there is more than one company.
   / John Deere and Yanmar #63
...Wasn't it Ford and BF Goodrich with Ford putting tires on SUVs that were failing?
You wanted "facts" and I gave you facts.
No, it wasn't and no, you didn't.
   / John Deere and Yanmar #64
Not sure how the tire diameter debate relates to the JD and Yanmar discussion. But here's hoping that JD can match Yanmar's engines. That's not going to be easy. Yanmar can make a pretty good claim for legendary reliability too.
BTW, for 4wd and tranny stress the critical tire parameter is "rolling circumference"....not diameter. Matching diameters only gets it in the ballpark. For that matter, I'm not convinced that measuring the diameter of unmounted tires tells much about the size they will be when mounted on rims, inflated, loaded, and run in. Does anyone know more about that?
rScotty
   / John Deere and Yanmar #65
rScotty
Kind of at a loss on the relationship too, but when I went to buy new tires for my Case, I was unable to find matching tires from the same manufacturer no matter where I went or who I tallked too. I was told that the tire companies simply could not keep up with the demand in my size tire. Now that was three months ago and maybe things have changed. I did check several dealers and all had matching tires, so either they got priority or bought ahead of time or all of the tire companies are using their production facilities to manufacture the more commonly used large AG tires.
I am nnot really sure how much if anything you can tell about the quality of engines/transmissions and such based on tires. A good dealership will take the time during setup to make sure tires match while a poor one won't much care one way or the other no matter what the brand.
   / John Deere and Yanmar #66
I posted this before (#47) but here it is again.
http://www.tractorbynet.com/forums/build-yourself/146256-measure-your-tires-your-bx.html
Here's the BF Goodrich recall:
http://www-odi.nhtsa.dot.gov/recalls/results.cfm
"Results : 1 | All records displayed
Brand Name: BFGOODRICH Tire Line / Tire Size: LAND TERRAIN / P235/75R15
Production Dates: FEB 29, 2004 - AUG 19, 2004
Manufacturer: MICHELIN NORTH AMERICA, INC. Mfr's Report Date: FEB 03, 2005
NHTSA CAMPAIGN ID Number: 05T002000 N/A
NHTSA Action Number: N/A
Component: TIRES
Potential Number of Units Affected: 41797
Check to Request Research. Submit below."
   / John Deere and Yanmar #67
It shows quality control. Skimp on one spec good chance there are other specs out.
The dealer in question went through all the tires and couldn't find a good set. The guys bucket was noticeably lower on one side, who watched that thing come off the line? Hellen Keller?
   / John Deere and Yanmar #68
Office of Defects Investigation (ODI) Server Error
Component: TIRES
BFG might have had a recall, but it was the Ford Explorer and FIRESTONE tires that were failing.
Ford Explorer Rollover
   / John Deere and Yanmar #69
Yep. Those are the "facts." The truth is in the details, and when the details are omitted or are simply wrong, the statement isn't factual.
   / John Deere and Yanmar #70
All I know is that I have owned two Kubotas with absolutely no problems including tires.
I could easily sat three trips to the JD dealer with deck lift problems and it still isn't fixed is indicative of poor quality control, but anecdotal evidence doesn't prove much.
Having owned more than one of each, I just do not buy it.
2121 (A58376)
2121 (A58376)
EZ-GO Electric Golf Cart (A57149)
EZ-GO Electric...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2012 Ford Explorer Limited (A57148)
2012 Ford Explorer...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
