tk tom
Keep in mind that the X series Deere's really shouldn't struggle to beat any Husqvarna or 1000 series Cub. If these units are creeping in on the X series 3 or 5 mind you then shame on Deere is all I have to say.
I bought JD X380 this spring. I also have two acres to cut. I have a lot of trees, patio stone lined flower beds, little bit of inclines, a landscape mound that is about 100' long, about 10' wide and about 5' tall. I have a 54" deck on it. I was cutting before with a Skags 48" walk behind. Took 2 hours with the Skags and I walked at a decent clip for 6 miles. Just got tired literally of all the walking. I can cut the same area now in 1 1/2 hours. I have an open area that is about an acre that is a bit bumpy. The machine cuts nicely, as long as you adjust the anti scalp wheels like they tell you in the manual. The left pedal that lifts and lowers the deck is a lot easier than a lever. Parking brake is easy also. The seat moves back and forth and also has three different positions for the springs, which changes the way it rides depending on your weight. I wouldn't buy a gas engined mower that wasn't a Kawasaki, love their engines. Fuel injection is spot on, gas filler is big and in a nice location on the left rear corner. The 54" deck is as big as I could go and still fit in between some fences and flower beds. The extra 6" over the Skags 48" makes a very noticeable difference. I like the gas gauge and it has the hour meter and pto rpm gauge too. My favorite feature is the magic yellow button that lets you go in reverse with the pto engaged and keep cutting. Works like a champ. You don't have to hold it in the whole time, just push it rit before you step on the reverse pedal. Once you hit the forward pedal, it resets itself. The tractor seems to be built pretty well. I did a lot of looking, reading, and research before buying this. Most of the other machines in this size are not made to last, course they are priced cheaper, but I don't like throwaway stuff. I also bought at about the same time a JD2032 with a front end loader and a backhoe, for maintaining the property. I still have to get a brush hog, York rake, and box scraper. Bought them both from the same dealer, who gave me a very good deal and seemed very knowledgable. Hope this helps, any questions, feel free to ask.
Mike Hawkins
One thing I don't understand is the "safety" feature to disable the mower blade when backing up. Some units require pushing a button before backing up if you want to keep the blade turning. On the Husqvarna, you start the engine, then click backward one notch on the ignition switch. Doing that enables mowing while backing up and nothing else is required during operation. If you don't do that, the blade stops immediately when going into reverse.
Is there some huge hazard of having the blade turn while backing up that I don't know about? It seems odd to me that so many units have this disabling feature, with a very easy way to defeat and overcome it?
Regarding "X series Deere's really shouldn't struggle to beat any Husqvarna," that might have been true in the past, but seemingly not so now.
Well I would agree pretty much across-the-line that it's Deere's market to lose. The prevalence of Deere, mostly good engineering, and the culture they have built with cheerleaders and champions of Deere products is very strong. Also presumably supported by a mixture of real-life and also paid posters on forums such as this, and it's a strong presence and brand.
Based on my research, a "leap into a whole new series" of Deere mowers pretty much starts at the X5XX platform. That's a subjective judgment of course, but others have come to the same conclusion. When I was shopping, I found many who recommended the x5XX platform at a minimum if you were adding attachments to it to expand the work scope beyond mowing. The impression it formed was that the x5xx platform had the engineering to properly support those components. Maybe not so much on the lighter platforms. I've compared prices of the Husqvarna vs an x380, but had I bought a Deere, I think I would have moved up to the x5xx platform for the reasons others have pointed out. Then the price was closer to $6,000 vs $3,000.
My case might be unique since my mowing needs are about a basic as you get. I have a Massey tractor for any work heavier than mowing lawn. And my lawn is maybe 1/2 acre, mostly flat. Although to be fair I did recently experiment with "brush hogging" using the Husqvarna and it did very well in one foot tall weeds. But that was an experiment, not a long term use. I'm confident the Husqvarna will mow lawns for a very long time and I don't need to exceed that scope of work. The former mower was an old Craftsman. I believe it was 12 hp and a 32 inch deck. It was much lighter built than a Husqvarna or Deere X3XX, and lasted over 10 years doing the same work task. So for me, a Husqvarna at just over $3,000 vs an X380 for $4,800 was a no-brainer. Not to mention my Husqvarna dealer was preferable to work with compared to the two Deere dealers I visited.
btw, I was referring to the Husqvarna in earlier posts as a Husky and another poster here corrected me. Huskee is a lower end mower sold at Tractor Supply. I guess some folks read "Husky" and confuse with "Huskee?"
