Just bought first tractor and got ripped off
   / Just bought first tractor and got ripped off #131
Yes weld it inside prep the area and weld a few passes and then grind the weld smooth don't take to much off the weld.
   / Just bought first tractor and got ripped off #132
I would post a picture or pictures and ask on the welding section here. Those guys are pretty smart and have done everything you need done multiple times. There are some serious pros there.
   / Just bought first tractor and got ripped off #133
I guess I have to ask the question, why grind it smooth after welding it? On the inside of a case, its not interfering with anything, the additional metal won't hurt anything, and it may help hold it. So why grind it smooth?
   / Just bought first tractor and got ripped off #134
Don't take to much off is the key moss!
   / Just bought first tractor and got ripped off #138
Yes. Why do it?
OK moss since you really want to know why grind smooth here how I would do it. Take a 4 " grinder use the side to gring open up the cracks wide enough to get weld metal in maybe 2 or 3 passes then grind it to look nice not like Joe blow gorilla welder.
   / Just bought first tractor and got ripped off #139
   / Just bought first tractor and got ripped off #140
Isn't that cast? I'd be taking it to someone experienced welding cast and has proper stuff to heat it up and cool it down slow etc. A bubba repair will hose it up worse and possibly to the point it can't be fixed.
2020 Ford F250 Pickup Truck (A55973)
2020 Ford F250...
15' WICK BAR W/ ALUMINUM MOUNTS (A52708)
15' WICK BAR W/...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
49205 (A55788)
49205 (A55788)
