Just can't see where I'm going
   / Just can't see where I'm going #31
One remedy I haven't seen mentioned yet: this site owner also has a new welding-specific site. 'WeldingSite'.
An experienced welder on there, recommended put a dark drape over the back of your helmet to block backlight in there. You could try an old black t-shirt. If it helps, then make a drape with heavier fabric attached with Velcro.
   / Just can't see where I'm going #33
My ribs hurt when I read dat "Welding Site" hard laughin do dat to me.
Miller sell anyting chinee prisoners make till bean counters at ITW figure out profit percentage not enough. Go to Miller welding board and read all about overpriced busted welding machines need fixin and no help from Miller. Once fine company whored to bottom of bucket by holding company.
BUY is evil vulgar 3 letter word. Men build girls buy. Real men look at catalog & steal design!
   / Just can't see where I'm going #34
One remedy I've used when welding outdoors is to wear a hoodie and flip the hood up over the back of the helmet.
   / Just can't see where I'm going #35
Not so strange ......... I've had this same problem when trying to plow my driveway in a blinding snow storm.
   / Just can't see where I'm going #36
But make sure your hoods or drapes are not of flammable fabrics.
   / Just can't see where I'm going #37
I was welding on a FEL maybe 10-12' from where a bit of ?? landed on the windshield and stuck. It's about the size of a grain of salt, only shows when the wipers are going, and an ice scraper won't budge it.
I've used a blanket to 'make dark' when working under a car hood in bright daylight. :rolleyes:
   / Just can't see where I'm going #38
I ruined and fixed a side window on my Jeep, when I accidentally threw grinder sparks at it.... Lesson learned keep automobile glass away for any thing that created sparks...
Dale
   / Just can't see where I'm going #39
Don't know if it was listed but make sure both sides of the glass are clean on your welding helmet. You would be surprised just how much that matters.
   / Just can't see where I'm going #40
Replace front and back plastic "spatter" guards when they become cloudy to a point they can not be cleaned....
Dale
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2013 NISSAN NV3500 CARGO VAN (A59575)
2013 NISSAN NV3500...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
