Kasco Drill advice
/ Kasco Drill advice #1
Smallplot
Pike County Illinois
1974 IH 1066, 1969 IH 756/FEL, and 2011 TYM T603 Cab/FEL
Does anyone have any experience with the line of Kasco Drills. I am contemplating buying one but have reservations based on this. In looking at videos of them it looks like the drills just drop seed on top of the ground instead of placing it at a predefined depth. Don't want to spend money on this if I just need to get regular no till drill. There are several models but I would need at least a 6 foot drill
/ Kasco Drill advice #2
Check the qdma forums, more than a few folks with them over there. I ended up going with a lightly used great plains over a new kasco, but kasco definitely has a fan club for food plots. They are much lighter than most no till drills which turned me off, but that may be a good thing depending on the size of your available equipment.
Thanks I will try that
/ Kasco Drill advice #4
I use a great plains drill. Well made. I picked up a used 2009 unit....
Thanks all. Went with the Great Plains also. Just could not get over the single disc opener and getting seeds to a consistent depth (other than a high priced cultipacker) with the Kasco. A seed drop tube that to me just drops the seed on top of the ground. Another benefit is my GP is true no-till .
2015 Peterbilt 320 T/A McNeilus 4029 28yd Front Loader Garbage Truck (A66736)
2015 Peterbilt 320...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
DRIVE WHEEL W/ PUMP (A65054)
DRIVE WHEEL W/...
2011 FORD F-250 SUPER DUTY (A67714)
2011 FORD F-250...
2016 John Deere 1200H Bunker Rake (A66734)
2016 John Deere...
2012 . Tri Axle Crude Trailer (A67714)
2012 . Tri Axle...
