5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,828
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Could be but not by Kubota.
I ran Kubota engine oil and used it on the first "early" change. After that, I have been using Rotella T6. I wanted to use full synthetic. I had a discussion with my Kubota dealer before I made the change. His final statement was, You can't find a better oil than T6.I assumed that someone slapped the Kubota label on their oil. I'm leaning towards Rotella T6
I use Amsoil in my on road vehicles, and had been using it in my zero turn gas mower. I looked up the specs on the Amsoil for small engines and the specs on T6 and the T6 was heads above the Amsoil in all respects, plus a significant savings in cost. I use T6 in quads, all my push mowers and my zero turn Husqvarna. As a credit to Amsoil, their synthetic 2 stroke (Saber) oil is wonderful. Had to clean the exhaust ports on my Lawnboy yearly or they would be plugged about 30%. I check the ports yearly now and in ten years I can still wipe the soot out with a qtip. Use the same oil in my saws.I ran Kubota engine oil and used it on the first "early" change. After that, I have been using Rotella T6. I wanted to use full synthetic. I had a discussion with my Kubota dealer before I made the change. His final statement was, You can't find a better oil than T6.
That said, I watch Menards most times I am there. I have enough oil for my next two changes. I gave up on Tractor Supply. It seems Menards have great stock on T4 and T6 5W40 and every once in a while a bottle or two in T6 15W40. I don't know why, but the standard oil turned black pretty early (as we think diesel oil should). The Syn. T6 seems to stay clear for a long time.
