Kubota 9540 front end loader install on m96s mudder
   / Kubota 9540 front end loader install on m96s mudder #1
Sniperwelding
High level ab
Looking for Kubota m96s
I am planning to purchase a new m96s Kubota mudder to move loads around in the mud and muskeg in northern Canada the problem is there is not a front end loader available for the 96 so my plan is to also purchase a new front end loader for a Kubota 9540 and modify it to fit on a m96 mudder I plan to use the 80"wheel width to allow side clearance for the large front tires and modify the back of the bucket plate to suit elevation change. Just wondering if anybody out there can tell me the frame width on a 96 and also on a 9540. Also looking for other ways or ideas that will work or loaders that will fit a m96 mudder.
   / Kubota 9540 front end loader install on m96s mudder #2
Have you checked for any aftermarket loaders? I seem to remember some owners using them, but I am not familiar with that model.
Never crossed my mind to look aftermarket but ya good idea Ill check out that option thanks
   / Kubota 9540 front end loader install on m96s mudder #4
I have a 9540 & 1335? loader. What measurements would you like?
   / Kubota 9540 front end loader install on m96s mudder #5
You sir, have the best avatar pic ever. I've seen that before and was wondering where I had seen it :laughing:
   / Kubota 9540 front end loader install on m96s mudder #6
Well thanks, that's a picture of Usta, my wife, or she (wifey) usta look alot like.. I mean kinda, or in my mind..... she really makes the JD green look good! (google images-girls on tractors)
Kind of a long process this hair brain idea I'm working on.starting to look like a LA1403E loader will bolt up to the m96 mudder then it is just a matter of wheel spacers,change exhaust,controls and plumbing,then change the the elevation on the back of the bucket. I think I'm on right track now and I have the measurements for the new plan. But thank you for the offer Rustyiron.
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2014 Ford F-350 4x4 Ext. Cab Palfinger PSC4216 2 Ton Crane Service Truck (A60460)
2014 Ford F-350...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
