Kubota B7100 Questions
   / Kubota B7100 Questions
Is the transmission lubricant the same for the manual transmission as the HST transmission?
My sincere thanks to all of you who have helped me with my Kubota education.
   / Kubota B7100 Questions #12
The original manual for the fwd gear drive tractor calls for 12.2 qts of any of the following:
Kubota UDT
Mobil Fluid 350
Exxon Torque Fluid 56
Front Differential 0.74 qt SAE 80 Gear Oil
Left and Right Front Wheel Gear Case 0.15 qt. SAE 80 Gear Oil
Recommended change is every 300 hrs.
Two drain plugs in bottom of transmission halves.
Strainer is the large center bolt in the suction pipe of the hydraulic system
I have used Amalie All Trac 245 for the last 10 or 12 years without any problems. Since the hydraulic system uses the same fluid (all one system) and I have the FEL and hydraulic dump trailer.... when I changed the fluid to Amalie I ran the tractor for a few hours after the first change and then changed it again to try to minimize any mix of different fluids. Not sure it was necessary but for the cost of the fluid it seemed to the right thing to do. I guess the proof is in the history. 22+ years without any problems except the battery which I have changed 3 times. Filters changed of course.
I have parts and owners manual so just ask if you need anything else. My B7100 is a 1983 that I have owned since new.
I stepped up to a B3030 this past summer the new tractor is great... power steering and lots more power /forums/images/graemlins/smile.gif but I still use the B7100 for many tasks.
BandD
Just the information I was looking for. Thanks for the detail, and for spending your time to look the information up and providing it.
I'm amazed at the knowlegable helpful people on this forum.
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
John Deere 204L (A56436)
John Deere 204L...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
Tractor Tires and Rims (A56860)
Tractor Tires and...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
Garbage Truck (A59230)
