Kubota Bs and Ls
   / Kubota Bs and Ls #11
Do you suppose this means there will be lower prices on the existing stock of "old" models? For those of us seeking a first tractor, that souonds very appealing!
Brad
   / Kubota Bs and Ls #12
Hi Mark and everyone,
Just back from an excelent dealer meeting in Salt Lake. Got all the info on new L's right here. L5030 is indeedy 50 Net HP, 42.5 at PTO on hydro, Cat I&II 3 pt hitch w/2980lbs lift 24" behind-dual external lift cylinders, live independent PTO standard on all Grand L's, stepless lever type cruise control--very precise control & you can turn with brakes(all Grand L's),InteliPanel dash is incredible. Kubota's website should be updated with the new info I believe on Oct. 1, maybe sooner. There should be enough just to get ya thinkin'-maybe droolin' too(I was!!)
Happy Tractoring, Christa
   / Kubota Bs and Ls #13
Thanks Christa,
Sounds pretty exciting. I will look forward to seeing the specs on all of the L models. Now I just need that Lotto ticket./w3tcompact/icons/smile.gif
MarkV
   / Kubota Bs and Ls #14
Steve,
I was told by an upstate NY Kubota salesman that the new models would not be available for purchase until springtime - is that accurate?
Brad
   / Kubota Bs and Ls #15
Hi Christa,
On the L3830 and the 4310, did Kubota increase the hydraulic pumps capacity(GPM), both for the power steering and the implements? Also did they improve the seats?
   / Kubota Bs and Ls #16
My dealer said he could do a really good deal on a leftover B2410 but I think it might be a little small for my needs. He does have a B2910 coming in about a week, I'll let you know if it's a good deal or a great deal.
Harry
   / Kubota Bs and Ls #17
Woodyed,
Yes on all counts. The previous Hyd Caps, were 7.8 and 4.1 impl.& PS on both models. New specs are 8.3 &4.9 for 3830 and 9.4 and 4.7 for 4330. The new seats are great. they are a contured, molded high back seat, with suspesion, reclinig seat back, weatherproof compartment for manuals, and..... armrests! The operators station is the widest in the industry and also slightly longer than the old models.
Omegaman,
Some models are supposed to be in warehouses by October--probably a longshot. You should certainly see some out by late this year, of course the dealers that ordered in SLC get the first shot--if they didn't it will surely be spring.
Christa
   / Kubota Bs and Ls #18
Christa,
Thanks for your reply. Am anxiously awaiting the arrival of the 3830 and 4330 at the dealers in my area so that I can see and drive them.
   / Kubota Bs and Ls #20
theboman
The B7800HSD is a new model with a 4 cylinder 30 hp engine, 22 hp P.T.O. "value" compact tractor. Real neat quarter inching valve on the 3 pt for implement hookup. 3 range hydro transmission. Same flat operator's platform as the other B - series compacts. Uses the same LA402 loader as the B2710HSD and B2910HSD tractors.
Lewis
PALLET OF MISC PUMPS (A54757)
PALLET OF MISC...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
UNUSED DIGGIT 20'X20' HEAVY DUTY ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
2004 Ford F-250 (A53422)
2004 Ford F-250...
