Mowing Kubota diesel overheating.
   / Kubota diesel overheating.
   / Kubota diesel overheating. #13
Actually, distilled water has the best heat transfer ratio of anything. AF is only needed when the ambient drops below 32 degrees (F).
Wrong. AF also raises the boiling point and helps the seals. If the engine has liners it helps the water side of them as well from pitting.
   / Kubota diesel overheating. #14
Whatever you say boss but I suggest yo do some research on the subject. I said distilled water, not tap water, distilled has no mineral content. The only seal is the water pump seal and modern pumps use a metal seal.
Care to provide a link to substantiate your claim? Maybe I should say, can you provide a link?
   / Kubota diesel overheating. #15
Straight water cools better, usually. You raise the boiling point of water chiefly through increasing the system's pressure, controlled by the radiator cap. Glycol adds very little to raising the boiling point (~10-15*F @ 50/50) and so is used mainly to lower the freezing point. Glycol mix also lowers the specific heat capacity (about 20% less @ 50/50) than pure water. That means as the 50/50 mix passes through the cooling system it is only able to carry away ~80% of the heat from the cylinders than pure water would be able to.
Pure water is generally teamed with a rust inhibitor additive and a cooling system booster that reduces the surface tension of the coolant, like Water Wetter and Purple Ice.
   / Kubota diesel overheating. #16
Replacing AF mix with straight water won't be 50/50 for long. Actual working load and ambient temps haven't been specified. Doesn't matter what the engine is in as much as how hard it's used and other operating conditions/details. Some flow isn't the same as prescribed flow of coolant or air. I wouldn't hang the bird on coolant ratio. My philosophy is that if there is more than one possible cause several are are in effect. Lets find 'em all.
   / Kubota diesel overheating. #17
Just clarifying a common misperception, not saying that is 4570man's problem.
We’re about to find out what straight tap water does. I’m going to go flush it with a water hose and mow some more. It still doesn’t have a thermostat in it. I’ll have to get one tomorrow.
   / Kubota diesel overheating. #19
With regard to actual heat transfer H2O is the best as he stated, cooling systems regardless of application are de-rated as the percentage of Glycol increases.
Well this might not be the by the book method to flush a cooling system but it looks pretty flushed and confirmed the water pump is working.
UNUSED FUTURE PC711 - 71" HYD PLATE COMPACTOR (A51248)
UNUSED FUTURE...
UNUSED FUTURE FT-X1200J STAND ON MUD BUGGY (A51247)
UNUSED FUTURE...
BUYERS PREMIUM & PAYMENT TERMS (A53426)
BUYERS PREMIUM &...
2019 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
