Kubota dozer blade
   / Kubota dozer blade #1
kuboman
Canada
B3200, L5740,
Does anyone know if Kubota makes a blade that will pin on the front of a loader in place of the bucket. I would like one for the loader on my B3200.:thumbsup:
   / Kubota dozer blade #2
W.R.Long makes such a blade, with the ability to angle.
   / Kubota dozer blade #4
Kubota made a frame mounted blade / snow plow. I believe it was for the B7xxx series. I have seen them for sale used and they look tougher than W.R. Long item.
Here is one for $500 I found searching Google
Kubota Front Blade FZB2019 > Capital Equipment > Used Equipment | Capital Equipment
   / Kubota dozer blade #5
If you have rear blade you could by an 3 point attachment plate for your Quick attachment. You could then use your rear blade on your loader. I would be careful how much pressure you put on the loader arms. I had considered a 3 pt attachement for my loader so i could use my boom pole to lift trusses and possibly a 3 point carryall as a man lift. Not that I would do that since you should not use a loader as a man lift......:eek:
   / Kubota dozer blade #6
looking for a unit like the one posted by Bruce Ward. if anyone knows of plow assy. I will pick up
thanks Nelson
Single Cedar Glider (A57454)
Single Cedar...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
16ft Canoe (A56859)
16ft Canoe (A56859)
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
