Kubota F series
   / Kubota F series #441
IMG_0193 3.46.34 PM.jpegPic of the weights
   / Kubota F series #442
I wished kubota made weights for the front of the ZD1511 :mad:
   / Kubota F series #443
Since I have both a ZD331 and a F3680, I actually think the ZD331 rides a little better. Both are rough on the posterior, but neither of mine have what I would call a really comfortable seat. The little rear tires on the F really magnify the bumps in lawns.
It’s the price you pay for traction.
The front mowing deck tires on the F don’t really transfer much “shock” to the operator since the front deck rolls in front of the machine more independently than the hanging mower deck on the ZD331 zero turn.
Thanks HD
THIS is kindly what I was also thinking.
I’m mowing 12+ acres I’d guess all around my farm.
It’s not a smooth yard or lawn but just looks like it :D
I wouldn’t want tires any smaller than the front tires on my ZD1511 for this reason mentioned.
   / Kubota F series #444
I have a Grammar seat on a different brand mower and it is wonderful. My back hurt awful with the old seat but with the Grammar it's zero pain. If you buy a new mower and the seat is an option, get it.
   / Kubota F series #445
As far as I know Kubota F3680's have no suspension at all in their seat base, but the seat itself may have springs etc.
Perhaps F3680 owners can clarify?
Here is an example of one F3680 seat base:
Here is a complete seat of another F3680 year:
Here is a seat of F3060:
The F3060 rides perfectly OK in our yard rough areas, but certainly there are better suspension seats for those willing to spend the money.
So different Kubota F models may have totally different seats.
I.E. buyer be aware and pay attention to this detail if mowing a rough yard.
   / Kubota F series #446
With fabrication skill an air suspension seat can be mounted to most mowers. The seat base for the Grammer seat was as I recall about 600 dollars and it mounted on the ZD331 with minor fabrication of brackets
   / Kubota F series #447
Doug,
Glad to see another "local" F3060 owner and I hope my suggestions below will be helpful.
Your question 1.
  • I got three SS spacers, in order to be able to use blades with 1-1/8" mounting holes. Been running Gator G6 Mulcher Blades 396-814 for one year with those. You will have many more choices with these spacers in place. I may go back to the OEM 70050-94622 blades next time just for comparison.
Question 2.
  • Our property is leveled enough that 4x4 is not really needed so I removed the rear drive shaft and have not noticed any grass stressing due to mower turning around, however it's obviously best to avoid "full lock turns" as much as you can and drive in big circles. Bigger the better. (I think F3060 has something similar to AWD when the shaft is in place) Our Grasshopper mower has bar tires and it's obvious to see the wear those cause when the ground is wet.
Question3.
  • Have you checked the 90 degree gearbox oil level? I switched to synthetic gear oil.
Question 4.
  • Check the steering for any slack, including the "king pin" plastic bushings 070 seen below. Once all good, double check the rear wheel toe-in.
Question 5.
  • In my mower the belt had to be flipped on it's back in order to slide out in-between the gearbox lower pulley & mower deck metal. IE the belt was or is wider than "taller" as far as I recall. In any case, it came out after flipping it 90 degrees. The pulley can be moved slightly up on the shaft, but in order to do so you need to un-mount the 90 degree gearbox.
Here is a thread I started little over year ago regarding the 90 degree gearbox in my 1997 F3060 mower.
90 Degree Bevel Gearbox on Kubota F3060 - 72" Rear Discharge Deck
I am still running the aftermarket 90 degree gearbox and it's working good, but eventually I will reisntall the OEM one and keep this for spare.
Plastic Bushings 070 & 030:
SS Washer:
arto,
I checked the gearbox lube level. I has plenty of gear lube. It smelled like dino gear lube. I’ll plan on changing to synthetic during this winter’s service downtime.
   / Kubota F series #448
   / Kubota F series #449
Nice job
Do you sit higher and does it affect leg reach to pedals?
I am fairly tall & large (6’ 230), so my factory seat bottoms out despite being cranked all the way to highest weight
   / Kubota F series #450
Nice job
It adjusts hight with a valve for air on the side of the seat. I set it to not bottom out and that Is likely somewhat higher than the original seat. It can also pump up fairly high to the point legs will touch handles
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
NEW Woods 6ft Finish Mower (A55315)
NEW Woods 6ft...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
