Kubota L4740 Engine "knock" Help?
   / Kubota L4740 Engine "knock" Help? #141
Thanks. Yeah, I guess when I said "idle", I was more referring to low-rpm in general. But it has to warm up, so I'll just try to do so as quickly as possible. From what I've read, you want about 10-15 hrs of varying rpm light-duty use, then work it hard for another 10-15hrs. Does that sound right? I gotta find some way to work it hard here in the winter...guess I could hook a couple of heavy logs to it and drag them around.
And I could have been more specific too. The problem with idling is that the engine doesn't get warm enough to burn all of the fuel. It doesn't matter if you are at 800 or 1300 rpm. A fuel droplet burns off in layers. If the engine is too cold the last layers don't burn. They end up in the oil. Not good because fuel is not a lubricant. This is true for both gas and diesel. That's why I recommended a garbage bag in front of the radiator.
One winter we had a really cold winter. I worked my motor with the snow blower but come rototiller time in spring I was amazed at the garbage that came out of the exhaust. It was condensed diesel fuel that hadn't burnt and it wasn't just a little bit either. So now if it's cold when blowing snow the tractor gets a garbage bag over the radiator screen. I watch the temp gauge and fold the plastic bag just enough to keep the engine cooled.
   / Kubota L4740 Engine "knock" Help? #142
OEM Kubota oil filter? I would also look at the oil filter to see if the oil relief valve was working properly. It should be fully closed at operating temperature to ensure full oil flow and pressure is directed to the engine oil gallery. Check spring, and seals.
Update: It's all back together and running beautifully! Man, it sounds so good. Purrs like a kitten. Didn't realize how much of a racket it was making before until now that it's gone.
Thanks everyone for all the input and help. Merry Christmas.
   / Kubota L4740 Engine "knock" Help? #144
CONGRATULATIONS!! Good Job:thumbsup:
   / Kubota L4740 Engine "knock" Help? #145
awesome!
   / Kubota L4740 Engine "knock" Help? #147
Good to hear and congratulations on a happy ending. Maybe give yourself a pat on the back since not many threads like this end so quickly with such positive results.
   / Kubota L4740 Engine "knock" Help? #148
:thumbsup:
I love threads like this. About the only chance I have of learning about the wheres and whys of engine mechanics. Thank you all for sharing your knowledge and informed opinions.
gg
   / Kubota L4740 Engine "knock" Help? #150
Very nice job! Glad you got it going again!
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
1660 (A59213)
1660 (A59213)
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2019 BOBCAT T450 SKID STEER (A60429)
2019 BOBCAT T450...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
