Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I added 800 lbs. of suitcase weights and 400 lbs. of liquid ballast to the front tires flleminj2pa
a great tractor & wise choice! i too went through several until i found the right model to suit my needs. you mentioned you added liquid ballast to the ft tires. my dealership mentioned to me it is not recommended to add liquid ballast to ft. tires...strange, when ft. suitcase weights can be added (to the frame bumper) was told it can put extra stress on the ft axle, power steering, etc. whether this actually holds any merit, not sure. i would recommend you post a thread on the subject, would hate to see you have problems down the line...been a great season for plots this year! best regards.
The old argument about front wheel liquid ballast putting extra stress on the front end doesn't hold water. If you can add front weights which most all mfg. allow that are equal to or greater than the water weight, then the ballasted tires are going to be much less stress on the front end that steel weights. I think this is just another ploy by the mfg'er and dealers to sell you steel weights. For the smaller CUT and SCUT tractors, adding 40 or so pounds of weight via the front tires is insignificant to induced wear. This would be no more weight to the front end than say the difference between a 150# operator and a 250# operator.
For the big Ag tractors on our farm when I was young, we always had water in the front tires along with front weights so we could carry the heavy 3 PH implements and still keep the front wheels on the ground. I don't recall every having to replace any components on the steering or axles of any farm tractors we had for Ford 8N to 9000 models and Allis Chalmers WD45 to One Ninety XT. Granted these were all AG tractors, none of which had FEL but all carried the max front end weights available.
Remember that all liquid ballast whether front wheels or rear put no weight on the front end, it is all carried on the tire. Only minimal extra effort is needed to turn the front wheels even at high speed, if you can call 14MPH high speed (14 mph is about the max most CUT will travel. I know someone is going to say "mine will go 16MPH", big deal, not enough to make any difference)
