RAllen
I have your model on my 2910. Have used it for 3 years to maintain about a mile of private, communal road and our driveway. I live in Montana and mostly get powder although we have a couple of wet dumps each year.
Our roads are gravel and my biggest complaint is how much rocks I pick up. I do have the skids extended to max. But rocks will migrate in the snow upwards even with a good snow base. A potato sized rock will jam everything and shear a bolt. I go through plenty of shear bolts every season.
Other than the pain of changing shear bolts, the blower has performed very well. I have enough power to take big bites of even packed snow to move snow banks.
If you are clearing gravel roads, I strongly suggest you mark alignment marks on your rotating blade shaft shear bolt holes and the non revolving collar attached to the interior shaft. When you shear a bolt, your vision is obscured by the grease inside the shaft and it is quite a pain to align everything since it always happens at the worst times and the worst conditions.
Alignment marks make it much easier. I started out with paint but ended up using a file and then covered the raw steel with paint.
You will like your blower. It is well made. Be sure to keep your chain adjusted as it will loosen up during your first season. /forums/images/graemlins/laugh.gif
Rick
Rick
