4shorts
Elite Member
Guys I just scanned 13 pages from the hydraulic section of the Kubota 5740 service manual. If you think this may help you out I'll start the upload.
oldnslo; said:JJ
my concern is that he does not have PB connected properly. Everything he is describing sounds like a series circuit where the tank port of the first valve feeds pressure to the next. By having the valves connected like this he would have flow to all functions all the time. That is what I asked him to check to see if the FEL system pressure followed his rear remote pressure.
Like spyderlk an you have both stated, there should be NO flow to the rear remotes when he is using the FEL.
The only logical explanation I can come up with now, is that the pump is capable of 3200 psi, and the pump flow is gong to the remote first, and the remote valve is set to 3200 psi. After that it goes to FEL valve.
