L 4330 make over
   / L 4330 make over #11
Sounds like you understand your chipper well. Can you slow the rate of feed? The thread may not be about chippers, but it is about power, something that chippers need plenty of. Good Luck...
   / L 4330 make over #12
Don't notice it over the other slop in the 3 point. The undersized equip. we run: Bushhog, 2 furrow plow, haying rake, haying tedder, log splitter, drawbar, spinner spreader, post hole digger.... hmm, oh and a tooth harrow.
</font><font color="blue" class="small">( Wouldn't the attachment slop around a lot with out bushing? )</font>
   / L 4330 make over
The feed rate is as low as it can be. When I chip 5" thorn apple wood that is where I run out of power, If I stop the feed and let it catch up I'm ok, but sometime I don't catch it qiuck enough. Often said that I wish I had an RPM gage mounted on the chipper.
   / L 4330 make over #14
The Dasko had an auto feed feature. It worked off RPM. As soon as the RPM of the engine falls below a determined point, it stops the feed. You still have control on reversing the feed as well. A little electronics and an electric solenoid hydraulic valve is all it was.
   / L 4330 make over
I think that Bearcat has that feature as an add-on. I will have to research that again, cause it would be a lot cheaper that a new tractor. Thanks for the reminder.
   / L 4330 make over #16
Deerlope -
I think RaT just solved your problem. When he switched me from my "tractor hat" to my "tree-guy" hat it all became obvious.
I have an 18" capacity Vermeer 1800 chipper with a 115 HP 4-cylinder Perkins turbo diesel engine that can be brought to its knees very easily when it gets into the big stuff. It has the type of auto-feed system that Rat refers to as having been on the Dasko (I think it was probably a Dosko) chipper that he rented. On my Vermeer, a hydraulic valve will stop the supply of hydr. oil to the feed rollers when the alternator voltage drops below a certain level (caused by the slowing of the engine as it tries to cope with "too big" a load). As the engine speed picks back up, the voltage goes back up, and hydr. flow to the feed rollers is restored. This is (IMHO) a must-have on any chipper that you can get it on. (As an aside, the newer Vermeers use an optical pickup to monitor engine speed and is even more reliable. Mine works fine though).
I also have two smaller chippers, both Promark model 210's, rated for 6" but obviously happier with smaller than that. One is powered by a 1-cyl 16 HP B&S gas engine, the other by a 2-cyl Kohler 18 HP gas engine. They pack quite a punch for their size, an amazing punch actually. In fact, back in the day, I once cleared a building lot with the 16 HP one and it raised more than one eyebrow with its spunk. They chew up pine and maple branches extremely well, as they are not self-feeding and like the straighter material like that. Twisty stuff like oak and apple is a major pain. But they do kick some butt, you just have to be careful how big/long a piece you feed them so as not to gag them.
That said: I have always wanted to put somethink like a 25 HP gas engine, or 20-ish HP diesel engine on them. With that additional power, they would gain a tremendous amount of chipping power, and give an even better accounting of themselves.
That brings me to my main point. You have 32 diesel HP at your PTO. PLENTY of power I would think to do some fairly serious chipping. The problem, as RaT pointed out, seems to be the lack of an auto-feed. Without the auto-feed, my 18" chipper would get plugged up 10 times a day, or require constant vigilance by whoever is closest to the safety bar that manually controls the direction that the feed rollers turn. Push on the bar, and the rollers reverse. Even WITH the auto-feed, we often "feather" big pieces into the cutters so as to avoid the lag time that the engine requires to get back up to speed after the auto-feed has kicked in.
Forget the 6800, or the injector tweaks. If you put the auto-feed on that I am glad to see is an option, your chipping experience will be a much more satisfactory one, I am quite sure of it. Also, I know you said the knives are sharp, but they need to be REALLY sharp. Just a little dullness has a geometric effect on the chipping ability of any chipper. I'd urge you to get at least one more set of knives so the other set can be off getting sharpened and you can still use your chipper.
Good luck, John D.
   / L 4330 make over
John, I just got off Bearcat's web site and have the info on the item that will give me the type of controller that I need. An electronic feed sensor.Going to call tomorrow and see what the cost will be. The knives in this chipper are reversable. But before the next use they will be sharpened. I had it stored for the winter but I had a 10dia pine go down so I got it out. Now its stored again. I am sure that the sensor will cost less that a L4330or 5030. Thanks everyone for all your help, input and advice.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Eagle Weathervane (A55853)
Eagle Weathervane...
