Lack of horsepower solution
   / Lack of horsepower solution #2
I've plowed many acres with a Ferguson TO20 and a Dearborn 2-bottom plow. Many of those were 1st time or many years since plowed. It seems the small tire size and weight of the Kubotas is the main problem here. It has to be a problem of traction instead of power.
You have to give these guys the ingenuity award though. They found a solution and the plowing looks good.:)
   / Lack of horsepower solution #3
I'll be hitting some untouched soil, hopefully pretty soon. Hope mine goes as well!
As for the 2 tractors, I wish I'd thought of that!
Jim
The two tractor concept is not new I guess.
YouTube - Deepplowing Flevopolder
I'm kinda bored today.
No dirt to plow, sitting at work with not much to do...
Watching plowing on youtube is the best I've got.
   / Lack of horsepower solution #7
I'll tell you the sad part of that is my Allis CA will pull just as good all by itself pulling 2 bottoms.
   / Lack of horsepower solution #8
Was I seeing thing or were the tires on the tractor the plow was hooked to not turning??
Bill
   / Lack of horsepower solution #9
Years ago, in the San Joaquin valley delta area in California, they used a five foot plow to turn over the silt in the flood plain. IIRC, they hooked together 3 or 4 Cat D8s to pull it, 130 drawbar HP each, tens of thousands punds of drawbar pull.
   / Lack of horsepower solution #10
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
10' CONTAINER (A52706)
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
Brandt Grain Vac - Mod. 5000EX (A59814)
Brandt Grain Vac -...
