Landpride boxblade$
/ Landpride boxblade$ #1
7snakes
JD5045e
Am purchasing a boxblade soon. Looking at a Landpride 7ft heavy duty (1119lbs.) Dealer seemed concerned at first about the size. Have 45 hp 4wd with ag tires. Shows me a lighter duty (593 lbs)7 footer and an even lighter 6 ft(504 lbs.) that is in stock. Will sell the instock 7 medium duty for $1150. Can't remember what he said it retails for. From reading here, weight seems to be a good thing for boxblades. Will be moving a lot of dirt with clay and maintaining drives. Is the heavy blade too much for my situation? Landpride literature shows 65 hp rating max for the heavy duty and 40hp max for the medium duty. Is the price a good one for the lighter one that he wants to sell that is in stock? Didn't get a price yet for the heavy one. Would prefer the heavy one if it'll work.
/ Landpride boxblade$ #2
Your tractor can handle the HD unit. Check the "side plates" of the box blade..if its HD they will be 1/2" thick (these are the verticle plates at the ends of the unit). Tell the dealer that you want something with 1/2" sideplates, if he can't get it, go somewhere else. I had my 7ft box blade shipped in from out of state as no one around here carried them (It came from Corriher down in NC). I don't even think they carry the HD unit any more..anyway, somebody will take your $$ even if your dealer won't. BobG in VA
I think he would order the hd, just haven't talked price and the talk of marginally pulling a 7 ft had me concerned. Was it just a case of trying to sell what's in stock?
/ Landpride boxblade$ #4
I think you may be right in guessing they are trying to sell what is in stock. It is hard when you are in business to order something in when you have something similar sitting there. However you are the customer and should get what is best for you. Keep looking around for the one that will work best for your situation. Communication is a great thing so talk to them and hopefully they listen.
Just wasn't sure of the HD weight and my tractor-quite a bit of differnce between the 2.
/ Landpride boxblade$ #6
Why seven foot? I ask because I think of most 45 hp tractors having roughly a 6' rear wheel width. I can understand the dealers concern about pulling the 7'. Once full of clay/dirt it is going to be a heavy load. Traction and travel speed will most likely be the issue. If it were me I would rather have a 6' HD, if close to covering your tracks, than a 7' med duty. The added weight of a HD really shines when working hard packed drives.
MarkV
I have the rear wheels turned out so it is wider-thus 7ft desire.
/ Landpride boxblade$ #8
I am a fan of HD equipment. However, 1119 lb box blade, 7' wide is probably a bit much for a 45 hp tractor. For cutting dirt, the scarifers are the key and you don't need much weight to get the scarifers to bury themselves. I would tend to look at the 593# unit.
I have an 82" HD gannon BB which is probably near 900-1000 lbs, a Kubota (gannon) 6' BB near 650 lbs and 5' gannon near 550 lbs. The real heavy gannon is a little harder to manage when final grading due to its weight and can dig too much or not smooth enough. I use the larger, HD gannon the least.
I would consider hydraulic scarifers if you plan to use it a lot. My 6' and 5' have hydraulic and the 82" has manual rollover scarifers.
/ Landpride boxblade$ #9
I agree you would probably be very happy with a med duty. Covering your wheel treads is important so I agree the 7 foot makes sense. I've never seen one with 1/2inch side plates, that seems a little over kill and the side plates don't take that much aof a beating. I've bent scarifier teeth but thats the only thing I'v ever bent. I break traction before I can bend anything else.
/ Landpride boxblade$ #10
your 45 hp 4x4 will even pull a 8 foot box no problem.
Well, I think I've settled on the 7ft medium duty blade. Emailed the company and they advised that the HD 7 footer would probably be too much for my setup. I appreciate the help and advice of those that responded. I'll update after I get some use and some pics. Thanks.
/ Landpride boxblade$ #13
My point was that if it doesn't have 1/2" sideplates, it ain't HD....if something less works for you that's great..I usually pull mine with a 60hp 4WD...anything less will turn into a pretzel over time. BobG in VA
/ Landpride boxblade$ #15
I have a medium duty 7ft landpride that I use with my JD110, which is 43 hp engine. It pulls it just fine and I have R4 tires, you will be fine.
Ok, here it is. Got a little bit of practice pushing/pulling snow, cleared 2 drives and moved a little dirt. I think I'm going to like this alot and look forward to really putting it to use.
/ Landpride boxblade$ #17
Seven foot is to heavy for that tractor. You would be better off with a smaller blade that you can run in a higher gear. In clay you will have to run in probally second gear which makes a long day if you you have to move it very far.
Jeez Dick! You probably thought you burst my bubble didn't ya? Your reply is not what I anticipated from reading many other nice knowledgable posts on here. You're not a bitter dealer are you that missed a sale? In reality, I emailed numerous dealers inquiring about prices, but they didn't seem interested in selling any equipment as they never replied-must have plenty of business. Speaking to others that routinely operate box blades directed me to this size. I had zero problems today-and I'm pretty sure I won't in the future either. I kind of doubt you are the "old,experieced wise owl". So far I am happy.:p
Here is a couple of shots of some dirt moved to cover a culvert. Will work on it some more when it dries out somwhat. The blade did a nice job digging into the clay.
Mini Universal Concrete Bucket (A65640)
Mini Universal...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2015 John Deere 35G Mini Excavator (A62613)
2015 John Deere...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2007 FREIGHTLINER BUSINESS CLASS M2 SPREADER TRK (A64277)
2007 FREIGHTLINER...
