Lifting front of tractor with FEL
   / Lifting front of tractor with FEL #11
NoMo said:
Using the bucket to lift the front of the tractor is actually required in order to install or remove the loader from my tractor.
Our loader requires the same procedure.
Our BH stabilizers will raise the rear of the tractor although the correct use of the BH requires the rear wheels stay on the ground.
   / Lifting front of tractor with FEL #12
The normal use of a FEL places enormous strain on the front end of the tractor. With the front end off the ground wear is easier to detect, loose bushings, etc. Maybe the dealer didn't want to repair or disclose normal or excessive wear. More likely the buyer was just being a PIA. Either way I'd walk away from a tractor if the seller would not let me lift the front with the FEL. MikeD74T
johnk said:
Pineywoodsrooter,
What kind of tractor was the guy testing out? Maybe that will give us better insight.
We looked at a lot of tractors that day. I thought it was a medium size (35-45 hp) John Deere. My son said it was a 75hp model (he's probably correct as he was paying more attention to the bigger tractor$):D
Regardless; after reading all the replies saying it's OK, I believe the dealer was trying to get the guy (who was reckless and very obnoxious) off the tractor.
PWR
   / Lifting front of tractor with FEL #14
My FEL lifts the front of the tractor effortlessly. Almost before you know it in some cases. And like others have mentioned, lifting the weight off the front of the tractor by using the dump cycle for the bucket is part of the procedure to remove the FEL.
   / Lifting front of tractor with FEL #15
I thought downward pressure is standard on FELs in this day and age
   / Lifting front of tractor with FEL #16
I don't believe that lifting the front wheels off of the ground will hurt a unit.
BUT, I don't like customers doing it with my equipment unless they are very serious about purchase.
Why? Because if you just go straight down thats fine, if you push the bucket to dump then you drag the cutting edge accrossed the paved lot, then when you either set it down or curl the bucket it digs into the pavement usually makes some nasty looking scrapes into the bucket cutting edge.
If the guy on the unit was being a jerk , as stated by original poster, then I can see why the dealer didn't want the customer doing it.
He may have sensed the customer wasn't serious and was just playing.
I've been there on various occasions.
If you are serious about the unit and are really wanting to "test" something I doubt the dealer would have a problem.
BTI
   / Lifting front of tractor with FEL #17
Piney Woods Rooter said:
I was watching a guy “test drive” a tractor at a dealer when he tried to lift the front end with the FEL. When the dealer asked him not to do it the guy replied “that’s how everybody always tests the hydraulics – my daddy’s been doing it for years” The dealer then (politely) explained to him that the FEL wasn’t designed to apply that much force in the down direction and that it’s probably not a good idea.
That explanation makes sense to me, what do you guys think? Should the FEL of a modern tractor be able to safely lift the front end? (The guy doing the test driving was being a real pain and the dealer may have just said that to get him off the tractor.)
What about forcing the FEL bucket down to anchor the tractor, say when using the backhoe?
Should the stabilizer legs of the backhoe be able to lift the backend?
Thanks,
PWR
PWR,
One of the many ways to lift the front with an FEL is to set the bucket down flat on the ground and then use the bucket cylinders to "uncurl" the bucket, rotating it downward away from the tractor.
When you do that, the bucket cylinders are extending. They have the most force possible applied. They will easily lift the relatively light front end of the tractor and will not harm anything as the maximum force is the weight of the machine's front. Unless you have chained the machine down to the ground!
jb
   / Lifting front of tractor with FEL #18
My dealer demo'd my tractor by lifting the front end off the ground.
   / Lifting front of tractor with FEL #19
I wonder if the next thing out of the dealers mouth would have been - don't start the tractor it shortens the engine life...
Not lifting the front with a FEL - that's just crazy talk... if you were not supposed to do that - there would not be a FLOAT valve...
   / Lifting front of tractor with FEL #20
Might you explain that a bit further, I don't understand what one has to do with the other.
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
Mini Skid 6 Way Blade (A56436)
Mini Skid 6 Way...
