Lilredfox sending out SOS
   / Lilredfox sending out SOS
will do... if that wires sheeth is crusty n brittle. being the retired lectrician i am. i'll replace it. thanks U.
Water may leak in around that wire, can also enter thru broken insulation in wire, I would clean and seal both with black silicon. How is the shifter boot and any other seals?
Dave
do u think i awwta dig out n replace all that igsisting wut looks to be black permatex runnin along the top seam.
Dave
thanks fur the link. that jus saved my hide n sure anserd alot.
lilred,
Your next step should be inspection of lift piston mechanism. It'll take 1 hr max and $10 cost to replace the nylon seal. I have sent you links and suggestions to correct. Have not heard feed back if you read them all or done some of the suggestions. You can abandon this thread and just follow the links and I'm confident you'll find all you need for a complete repair. You do not want to destroy you injector pump or the hyd pump, if you do so then that tractor would be scarp metal at best.
I have a link here for you that show how to replace injector pump oil that is separate from crankcase
JC,
good luck.
http://www.tractorbynet.com/forums/...-pump.html?highlight=ford+1700+injection+pump
is there a prefered flavor of oil fur the injector pump? all it sed in what i read )thanks again by the way)is to use a good motor oil. i myself prefer castol GTX. wut weight do i use?
keeping in mind it is turning rather chili out there.
No question, is a dumb question, if yea dont no the anser!!!
lilred,
JC,
good luck.
   / Lilredfox sending out SOS #165
I've gotten a real kick out of following this thread, and I was really impressed with the fox until I saw the Semi-holes cup on the bench. Now I have to question her commom sense.
   / Lilredfox sending out SOS #166
I use my engine oil. For my Ford I use diesel Rotella 15W40 for the crankcase and same for the injector pump. You might get a bit of compressed air with a nozzle to push some air from the top with the drain and level hole open on the pump body. The link has pics that show were they are. I bet ya that oil will be thick and dirty. Castrol is perfectly fine but you want to make sure it is rated for Diesel application. Agreed .:)
that semi-holes cup was given to me when i first arrived here 4 yrs ago. i soon found out that as soon as wunna the locals finds out ur new round these parts. the first thing they do is corrupt u. common sense tells me not to take a coffee cup out to the shop i dont wanna get broken... :duh:
i.e. dont care bout that cup.
   / Lilredfox sending out SOS #168
i checked them out as well. both boots are tight. there is nothing anywere that i can find that would permit 3 xtra gals of fluid get in there. and certainly not in a 6 month period of time. not even sittin out in constant rain.
I would replace both boots, the left one is loose fitting around the shift lever, you would be surprised how much water runs down a shift lever, the right one looks dry rotted.
I dont beleave there should be any sealer on top, between the cover plates, someone may have been trying to stop water entry.
i pulled both boots down wen i checked em. they both do seem tight. i hadnt set it back in place after i took the pic. bedder ta be safe than sorry. agreed. there shouldnt be any sealer on top. i think perhaps my pa put it there. prolly was leakin or he thot it might could leak.
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2013 GALYEAN 130BBL VAC TRAILER (A50854)
2013 GALYEAN...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
2020 KUBOTA RTV...
