Liquid or granular residential lawn care?
   / Liquid or granular residential lawn care? #31
You can download the TeeJet book in PDF format and print it.
Thanks, I printed out some of the .pdf's earlier. Unfortunately, my b&w printer can't reproduce the color and gray shading in the brochures good enough for the fine print in the tables. /forums/images/graemlins/frown.gif
   / Liquid or granular residential lawn care? #33
I will offer you the following, JMHO from 29 years in the lawn business. Dimension & drive 75 for crabgrass, talstar for surface insect control, merit for grub control, trimec,speedzone & confront for broadleaf weeds. 5 apps of fertilizer, 1 every 6 weeks, Lime as needed for neutral ph, 7.0 is great, anywhere from 6.7 to 7.4 is ok. core aerate each fall, cutting height of 2.5" all season, 1 " of water per week and you are good to go!
   / Liquid or granular residential lawn care? #34
I follow the scotts 4 step plan but I don't use scotts products. Scotts sends me an e-mail when each step is due. I then shop around and find a product that has the same ingredients as the scotts does. As for weed control other than crab grass I just use a little 24d in my sprayer. Sometimes all I buy is just plain fertilizer and use the 24d for the rest. I like using dry for the fertlizer and liquid for the weed control.
   / Liquid or granular residential lawn care? #35
Is the topsoil up your way as rich as say evanston? I have done some excavation there & couldnt beleive how ritch, deep & rock free the soil was. Here in massachusetts the soil is rich for the most part, but its full of rocks!
Thank you. I appreciate that info, nothing better than first hand knowlege/experience from the pros. I've been wondering how to handle the insect/grub problems. The latter has not been an issue at this house, but we are beginning to see the black ants come alive. I've used a diazanon spray barrier around the house foundation in the past, but question it's effectiveness. Will a 'talstar barrier' work as well? Any other 'dog-safe' approaches to consider?
   / Liquid or granular residential lawn care? #37
I beleive talstar controls ants and ticks as well. I see you are in new york, tons of restrictions in that state!
Made a temporary 3-pt platform for the first application, I'll finish up the fancy carryall later. Ended up mixing 32oz each of 2,4-D and liquid fert. (1oz/1000sf), plus 8oz surfactant for each 30gal. tank fill, and put down about 4 tanks total.
After doing a bunch of calibration runs up and down the driveway with different tips, I was thinking the TeeJet TP8003 tips worked best. The neighbor, however, wasn't quite sure why I was watering my blacktop and came over to check it out.
Ended up mounting my little GPS to control calibrated ground speed of 2.75-3 mph. Seems to have made for an effective kill, the little yellow dandies are shriveling up. The first time is the hardest, should go a bit smoother next time. Thanks for the help.
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2014 Ford Escape (A50324)
2014 Ford Escape...
Freightliner Tender Truck (A55301)
Freightliner...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
