Log chain - HF vs. TSC
   / Log chain - HF vs. TSC #31
I'm a 3/8 G7 chain guy, but just bought a a 20 ft 5/16" grade 70 chain with G70 grab hooks from Lowe's. Rated at 4700 WL, stamped U.S.A. on each link.
Can't beat it for 35.00
Shop Campbell Commercial 5/16" x 20' Tow Hook Chain at Lowes.com
It's perfect for pulling logs, I wouldn't go trying to jerk stumps with it though. and even though it's rated plenty high enough to bind a CUT down on a trailer, I wouldn't. I still only use 3/8 G7 for securing equipment over the road.
JB.
   / Log chain - HF vs. TSC #32
I live in a simpler world. I have abou 6-7 utility chains of different sizes. 1 was bought at Lowe's,1 at harbor Freight, the rest were picked up at flea markets. The only times I have ever broken a chain, I was giving it the business or using too small a chain. I do have some transport chains that cost some cash, but they are required by law to tie down heavy equipment.
   / Log chain - HF vs. TSC #33
90% of ropes to chains breaking has been to "jerking" at least for me.
prefer chains i can run bolts through them. many times being able to run a couple bolts through a chain to tie things down. wrap around a couple extra logs. etc... has made life easier.
if i can use a couple bolts, i might be able to fix a chain that has broken.
on other hand. there has been a few cases were having shorter links were i could not fit a bolt through the links. would have been better. when hooking the chain back onto itself, for a tighter hooking / less sloop would have been better and easier. vs relying back on bolt through the links.
shorter length links. tend to allow smaller "bending radius" to wrap around tree trunks / branches. or perhaps around an implement or something on a trailer. so there is less sloop that needs to be removed via a chain binder.
it is a 50/50 deal for me. regardless, having a heavy duty chain. with a higher breaking strength, load strength. has been needed more of the times and been much more useful. vs a cheaper low grade chain.
the times lower grade or smaller size chains have been used for me. is when i end up breaking them. exception for chaining / roping some light weight stuff down in back of a pickup truck or on a trailer. and then i find having straps work better. due to most of the time. i do not want to dent, or bang the paint off of stuff.
other uses for smaller size chains, have been for gates and using a paddle lock.
i will tend to buy cable before rope and chain. when needing to pull trees / limbs up and out of wooded area were tractor can not get to. and in that i can use a pulley if need be with a cable.
   / Log chain - HF vs. TSC #34
For most general use, including skidding logs, I prefer high-strength 1/4" chains due to their lighter weight and ease of handling. I have never broken one of these. There is no way I would lug around a 3/8 chain for that type usage. The one time I did break a chain, it was a 3/8" (not in the best condition), and was using along with a double-pull, 1/2" cable and pulley setup to yank my nieghbor's Chevy Suburban "field-car" out of a mud bog with my 4wd, JD 4120. Each time I released the clutch, and took the slack out of the cable, I could move the suburban about 6" thru the mud which was up over its floorboards. I have a bunch of 1/2" cables, in various lengths that are real handy in cases like this where you can use a pulley attached to a tree to double your tractor's pull strength. I do use 3/8" for binding equipment to trailers however but those chains stay on the trailer and dont get lugged around the woods too often. It definitely pays to have an assortment of chains so that you can use the best one for every job. Most of mine have came from auctions, garage sales, or flea-markets. My favorite is a high-strength, 14 ft, 1/4", and there is always one in my tractor's tool-box.
   / Log chain - HF vs. TSC #35
As mentioned I just got my first piece of 5/16" chain, always used 3/8",
Don't think I could go down to 1/4", that seems to small. I have a couple of short pcs but rarely ever use them, maybe good for lawn tractor work.
If you are gonna buy chain, might as well get G70 IMO. That 5/16 20 footer from Lowe's is light enough to handle easily. 20 ft of 3/8 is pretty heavy.
Interestingly, when you go up to grade 80 the chain gets lighter, they call it alloy, not sure what percentage is alloy, but it is noticeably lighter.
JB.
   / Log chain - HF vs. TSC #36
For the 4K# 4120 Im sure hi strength 1/4 is very effective. This is what we use on our Kubotas. The short link ones are slinky and pleasant handling while being quite rugged and trouble free. Hi strength rated chains for lifting seem to be made using short link construction. My 5/16 SL chain stays on the 11K+ Mahindra. I use hi strength 5/16 bolts for incidental joining either chain when necessary. For joining end to end to extend a chain a 3/8 - or even 7/16 bolt will fit.
larry
   / Log chain - HF vs. TSC #37
Anyone know the working load limit of 9/32" H800 chain with Clevlock ends?
Thats what I use. Two 5 footers and a 10 footer.
   / Log chain - HF vs. TSC #38
JB.
They dont seem to make hi strength chain small enuf for lawn tractor work. 7/32 Gr80 would be huge overkill. 3/16 if available would be quite adequate, but both would be totally incompatible in a mixed tractor "family". 1/4" minimum for us.
larry
   / Log chain - HF vs. TSC #39
9/32 GR80 is 3500# ... H800 :confused3:
larry
   / Log chain - HF vs. TSC #40
I'm sure some of you will call this ridiculous, however,
an old farmer near me said that he makes a nick in his chains
with a triangular file on the link nearest his tractor. When I
asked him why, he said that if he is going to run the risk of
breaking a chain, he didn't want a long loop taking his head
off, so he put in a sacrificial link.:cool:
I guess whatever floats your boat.
Bill
excavator trenching bucket- one bucket per lot (A56436)
excavator...
1770 (A58375)
1770 (A58375)
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59575)
2017 ISUZU NPR 18...
