Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #151
FYI. When you go to buy those 50mm dinse fittings they're about $35.00 a piece! I suggest a cheaper way. Cut the leads that came on the machine about 18-inches to 2 feet from the male dinse fitting. Buy two female, and two male Tweco lead connectors. Should be able to buy a box of Tweco fittings cheaper than the dinse connectors. Here is a set for $13.01.
[ame=http://www.amazon.com/Tweco-SEPTLS35894251225-Weldskill-Cable-Connectors/dp/B002C0SVMA]Amazon.com: SEPTLS35894251225 - Weldskill Cable Connectors: Home Improvement[/ame]
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #152
Here is a likely stupid question. What measurment is the 50mm. 50mm is 2 inches, and nothing on them (that I can see) is 2 inches. The ones on mine are 1/2 an inch in diameter.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #153
I come up with .5110
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #154
Well in my defence the battery in the caliper was dead, so I had to go off the scale printed on the slide. Now that I think about it, I should have just got the one with the dial...
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #155
The ones I got for the PowerArc 200, I had to cut about 1/8 inch off in length to work.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #156
I just cut the original cable in half and spliced in a new section. Used copper crimp splices and heat shrink tubing.
Ian
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #157
Ok one thing I cant figure out about this fancy new welder is what the arc force does. Does it make the arc more focused? Does it make it dig more? I am sure it would be much easier to set it if I knew what it did. :confused:
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #158
Arc Force, When turned up, Will allow you to push a 1/8 rod through 1/2" plate without sticking or going out. Or, It can keep the stick lit when you suddenly go out of possition like when welding around a pipe or other obstruction. At least on equipment that I am familiar with and own. I have laid a rod almost flat on it's side and not lost the arc due to Arc Force being turned up. Try it..
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #159
Ok that will help. I will try messing around with the arc force as soon as I can.
   / Longevity Welding - MIG TIG Stick Multi Process Welders and Plasma Cutters #160
I have a Longevity plasma cutter that I bougt 3 or 4 years ago. I talked to Simon at length before I bought it and when I ordered it I had it in just a few days. It has performed flawless for this time I have had it. I had a problem with the gun after a couple years and was told to send it in. I boxed it up and had my wife send but she did not put Insurance on it and the mail system lost it. I call Longevity to check on it and was told they never recieved it. The person I talked to looked for it but it was never found so I told them I would have to buy a new gun. I was put on hold and when he returned he asked for my address and informed me that they were sending me one at no chaarge. I almost fell over. I thought what kind of company nowdays has service like that. I would buy from them again in the future if the need ever arises.
2012 Freightliner Cascadia (A56436)
2012 Freightliner...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
Sedan (A59231)
Sedan (A59231)
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
