Brad_Blazer
Veteran Member
That sure looks like wear to me - almost worn into the bolt holes. The road will put a nice bevel on a blade, almost parallel to the ground where the original bevel is much sharper. You see the same wear on the upper right corner where the blade has already been reversed once. I would reverse it back before the holes disappear and start looking for a new blade.
Check out these cut profiles. Both were from the same blade. Originally the whole thing looked like profile of the shiny cut. You can just see a little wear on the right edge. The rusty piece was cut where the blade was worn off by a good inch. Obviously the blade was never flipped, the left edges are still the original profile.
By the way - that's a real nice grader - wish I had one like it.
Brad
Brad
