looking for a blade
   / looking for a blade #1
taborekle
St. Marys County, Md.
Kobuta B2920
Hi all,
I have a Kubota B2920 with a 60 inch blade. I'm thinking of upgrading to a new blade but can't find one that I want. The features that I'm looking for are:
6 foot blade
Category 1, quick hitch compatible
capable of doing swivel
capable of doing tilt
has a quick offset for either side of center
Is good quality.
Is less then $600
Anyone have any good leads or has one that they can suggest?
   / looking for a blade #3
I am looking for an eight foot blade just like it for less than $800 let me know if you find one.
   / looking for a blade #4
would any of these scrape blade work? Not sure if any has tilt, but a couple of them fit all the other requirements I think . . .
   / looking for a blade #5
Hi all,
6 foot blade
Is good quality.
Is less then $600
I have a 7ft woods, quite serviceable, that I believe would work ...if you're interested ...Harpers Ferry, WV
   / looking for a blade #6
I also have a B2920. A Topeka dealer was going out of business and still had some left over Landpride equipment. I took my tractor there and put a RBT1560 and 1572 on it. There was only $30 difference in what he was asking in them, but in the end, I went with the 60" for $500. Admittedly it just covers my tracks when I have it at the most extreme angle, but the 6' one could not be tilted to the greatest angle without at least shortening the top link a lot and I am not sure it would make it then. I did not try it to be sure. The 3pt hitch would not raise it high enough.
After using it, I am ok with the decision. I haven't used it a lot, Mostly just clearing snow. But in the Spring, wanted the tilt capability to crown the drive better and also for the ditching capability. I used it to dig a ditch to put in a downspout drain line at my daugher's house and it worked well for that.
   / looking for a blade #7
   / looking for a blade #8
Check Tractor Supply. I think they have a "professional" grade with your requirements.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
