Loss of hydraulics and HST drive
   / Loss of hydraulics and HST drive #11
Indian Head will not provide a good seal.
From my New Holland service manual;
Well, the reassembly is going slow with the heat here in Maine the last couple of days. I did try and start to reassemble it today. I have the new pump and pump gear. My dilemma is getting all the gears and bearings lined up to install the transmission cover. I used the two long bolts from the HST as guides by screwing them into the transmission bolt holes and trying to slide the cover in place. I am having a bear of a time to get the 4WD shift fork lined up without losing the detent ball (I didn't remove the transmission from the tractor, just the cover), and sliding the cover in place and getting all the bearings and gears to line up. Something always seems to bind up. I have been able to get 3-4 bolts started but can never seem to get the cover to snap or slide into place. I am hesitant to over tighten the bolts and crack the case or break something. Anyone have any tips or thoughts? Much appreciated.
   / Loss of hydraulics and HST drive #14
Just wondering how this ended up? Not many of us have got this far into repairs, sorry if we weren't more help.
Well, it has been a slow go as I am working on it myself outside so the heat has been hampering me. I will confirm that when you lose the hydraulic pump that is mounted outside of the transmission and sits above the suction tube where the mesh screen is you lose HST, power steering, and hydraulics to the loader, 3pt lift, and backhoe. Fluid is pulled up from reservoir via the suction tube, from there it goes through the pump and out to the power steering and loader control, the return from these is attached to the transmission case where it flows through internal piping to the filter inlet, the filter outlet flows internally to the input/suction port of the HST, the output from the HST dumps back into the transmission case at the top of the HST. I hope this is clear and can help someone else. I got the tractor running today and mounted the loader and it worked great, the power steering worked, the HST worked, the 4WD worked, and the Hi/Lo range worked. What didn't work? The mid and rear PTO have a noisy ticking, sounds like a gear isn't meshing correctly. And my 3pt lift isn't working which also means I am not getting any hydraulics to the backhoe. I have checked the linkage to the 3pt raise/lower lever and it is hooked up and moving the control. I haven't researched it yet but I am thinking a stuck bypass valve or pressure relief valve. One step at a time.
CAT CS563 (A47477)
CAT CS563 (A47477)
Golf Cart (A55787)
Golf Cart (A55787)
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
2017 BOBCAT T650 SKID STEER (A52707)
2017 BOBCAT T650...
