Love my BX!
   / Love my BX! #31
Barryh said:
1*loved the way the engine runs seems very powerful and I like the ride and the
2* muscular build for a small tractor.
1*I've read different post where some folks were of the opinion the engine vibrates excessively.
I have to admit that it shakes around under there more than does my BX23 3 cyl.
However it you reve it up just a slight tad It runs nearly as smooth and quiet as the bx23 so I don't find vibration a concern with the BX1500 2 cyl engine.
2*I don't know how many times i've commented to my wife {Boy that's a lot of tractor for such a small tractor}.It's about the same size as my Cub Cadet GT2554 garden tractor but it's way more than twice the tractor.
   / Love my BX! #32
LBrown59 said:
1*Just got my 2003 BX1500 on 11/8/7.
It had 380 hours on the clock.
Seems excellent so far except it needs a new right end for the seat belt.
The buckle won't snap into it.
Dealer is sending me a new one this week some time.
One tail lite is out / haven'f had time to put a new bulb in it yet.
2*So do I, but I figured I would if it was any thing like my bx23.
Love That Tractor.
Just like my BX23 it constantly amazes me.
3*Y shure Y not.
Well sounds great.... With all of those tractors who would have time to work on one..:p Just kidding of course. I also have a John Deere 140 H-1 a Cub Cadet 105 and a Craftsman yard tractor which any of the three will mow the lawn. I got the BX 1500 mainly for landscaping my place.
I had a nice Power Trac 180 with front end loader. It did most of the ground work around here. My neighbor next door bought it for his place. So I still get to see it every weekend. I had to replace 4 hydraulic hose's on the BX 1500 and now it's running great. Next weekend I'll change out the SUDT fluid and a add a new filter, along with changing the oil filter and adding synthetic Mobil one.
So far I need to replace the right turn signal and, I noticed it will need a right tie rod. Has a little play will go ahead and change both while I'm at it. Other than that I think I got a great little tractor here. So how about pictures of all your BX models???? Would like to see a couple of these tractors in action. :rolleyes: :p Here's a few of mine. Next weekend I'll clean it and shine it up a little. Could use a little touch up paint as well.
   / Love my BX! #33
docspencer said:
So far, the BX has been wonderful. It's my first SCUT - before all we had was a Cub 2160 lawn tractor.
*Occaisionally, I wish I had a bigger tractor, but generally this one is just great.
*I've never wanted anything bigger than my BX23 but for the last couple of years I've been wanting a smaller BX1500 to go with it.====
===Well that dream came true Thursday 11-8-7.
Two of them are setting in my garage now.
1 new one and 1 used one.
   / Love my BX! #34
MMCSKPD said:
Wow... I don't think my BX-23 was that clean and bright the day it arrived from the dealer. I have 330 hours in 3 years and it looks like its been in a Mud Bog most of its life. I sure love it. I put down 23 ton of 2A limestone with it today. I finally broke down and put BX-24 front wheels and R4 tires on it last week and I got them Foamed. I have had 12 flats and had to replace 2 tires since I got the BX. As soon as I can raise the money for new rear tires and $400 worth of Foam, I'll be putting them on. The foam on the fronts was $52/tire and foaming the Rears will be $206/tire.
I have empty ags on mine and have no plans to change them .
The FEL and BH is all the weight I need.
Never had a flat.
   / Love my BX! #36
DiezNutz said:
3.5 years and only 200 hours ?!! Probably still has that new tractor smell!
C'mon Man, you gotta get to work! :D
I hear ya... the only wheelbarrow I own is this 30HP 4WD one. Some days that's all it gets used for....good excuse as any.
3 years and 900 + hours on mine.
   / Love my BX! #38
jcpwrsprt said:
Let's see your "cute couple" ;)
Yep, I would like to see him line them all up for a few shots..:eek:
   / Love my BX! #39
Barryh said:
.... Next weekend I'll change out the SUDT fluid and a add a new filter, along with changing the oil filter and adding synthetic Mobil one.
...Next weekend I'll clean it and shine it up a little. Could use a little touch up paint as well.
Don't forget to clean the hydraulic systems filter screen on the side of the differential when you change the fluid. It sounds like that one has been abused or at least, ill-maintained. The amount of metal particles will neither point out if it has never been cleaned or simply abused. Unfortunately you will never know which. The fewer the better, however!
Kudos to the thread. Yesterday evening, I took my BX2230 and finished a small trench for spring thaw with the Wood's Groundbreaker-X (BH6000), scooped the loaded piles of earthen clumps with the loader (how do you turn up the lift?) and made numerous trips to the field, got back in the garage by dark and by kerosene heater (and a tall Ardbeg on the rocks) dropped off the loader and BH, stowed away in the garage for winter, put the arms back on the 3PH, took off the BX grill guard, hitched, leveled and snugged the ballast box, loaded on the front Quick Hitch hyraulic lift (spelling or scotch?...you decide) and proceeded to hitch the BX2750B front mount snow blower. Finally, connected the long and short PTO shafts, bolted the manual chute rotator arm, tested and parked to wait for the first snow.
Yup, does just about anything doesn't it?:D :D
   / Love my BX! #40
Thanks for the tip on the hydraulic systems filter. Any other tips from anyone are welcome. From what I can tell this machine hasn't been abused but, from the looks of everything has been as you put it, ill-maintained. That is a form of abuse in it's self. So I won't be working it hard until everything is up to par. I need to find all of the grease zerks while I'm at it.
As for Mr. browns comments on vibrating engines. I was amazed at how the two cylinders run so smooth and strong. Yeah sounds like your ready ;) The snow is a coming...:)
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
City of Buckhannon - 1990 International 2574 Truck (A52384)
City of Buckhannon...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
