blb078
Are non LS filters ok to use and not void the warranty? And anyone have any info on the newer LS engines in the xr4100 series?
Yes, aftermarket is ALWAYS fine for warranty purposes as long as they meet the manufacturers standards. They have to prove it was the fault of the aftermarket parts. The only legal way to require OEM only service parts is to provide them free of charge.Are non LS filters ok to use and not void the warranty? And anyone have any info on the newer LS engines in the xr4100 series?
Once the cross-reference from LS 40006977 to an after market supplier is revealed, they lose visits to the dealership, they lose their sky high shipping and handling charges. All it takes is for someone at "Big Filter Company" to obtain the LS oil filter and have the engineer tear it apart. Why that hasn't happened is a mystery.
Rowdy,
Any problems? I'm hearing that the (oil) filter for your machine and my machine may be the same. I have an XR3135H and having a hard time finding an aftermarket oil filter. Sounds like you scored but did it work?
When you consider this entire thread, here's how it turned out. I found that planning to do my entire 50hr myself was a confusing endeavor. My book says that only two fluids need to be changed and everything else "checked". My dealer had it quite the opposite. If you scour the web including this site, you should flush everything factory and start anew and then future maintenance is solid. Everything else excluded, I am a hostage to my dealer for the oil filter. Merles, Napa, Wix, everyone agrees that it exists. No one has it in stock. XR3135H is a new LS with a new LS engine. In a few years, we'll be swimming oil filters. In fact, it's rather cheap at the dealer, but everything else is going to cost me out the butt. I hope everyone else has the patience to hang on for the filter to go public but I want my 50hr out of the way and to travel on with my machine.
A little update on realhunters post since RCO doesn't put the actual filter numbers on their invoice. They substitute baldwin filters for everything the y can. I have a 2016 LS XR4150HC so here is the list I have of filters which also includes the HST filter:
Hydraulic filter: Baldwin bt839-10 or wix 51551MP
Oil filter: Baldwin B243 or wix 51516 or 51516XP
HST Filter: No Baldwin match, Wix 51715
