Mahindra HST problem
/ Mahindra HST problem #1
SooperYooper
Mahindra 3540 HST
Mahindra 3540 Hydrostatic. When I press forward or reverse pedal I get a several second delay before the tractor starts moving. I've been banging my head against this for a few days and would appreciate some input.
- Sudden change, not a gradual worsening
- When tractor starts moving, it is not a jerking motion. Its just a slow ramping up. Does not change with RPM.
- No unexpected noises.
- Identical problem in forward and reverse.
- Loader performance is normal.
- Once tractor starts moving, it seem to operate fine under load.
- Changed fluid and filters. Cleaned HST suction strainer. Nothing out of the ordinary noted.
- Checked charge pressure at oil cooler and got ~300psi, which is within spec.
- Backhoe had been on for 6months. Problem started day after taking it off.
Does anyone have a suggestion on what to check next? After ruling out the simple things I expected to see a low charge pressure. Since that pressure is fine, the service documentation suggests this implies damage to the HST itself. I'm really really really hoping I'm missing another possibility.
Any help would be greatly appreciated. Thanks!!
/ Mahindra HST problem #3
Does your back hoe require activating one of the rear remotes to operate or does it have dedicated quick disconnects for supplying oil?
If dedicated quick disconnects did you install the jumper hose required when hoe is removed?
Thanks for the suggestions! There are rear remotes that need to be activated for the backhoe. The lever is in the neutral position.
I can't think of a reason the backhoe would be involved, but I did think it was worth mentioning that it happened a day after removing it. I attach and remove the hoe a few times each year.
/ Mahindra HST problem #5
Maybe put the hoe back on and see if the issue goes away.
/ Mahindra HST problem #6
Does that model tractor have electronic control for the HST vs mechanical? If yes wondering if possible a wire or connector was somehow compromised during removal of the hoe. Since same in both forward and reverse points towards a common element.
/ Mahindra HST problem #7
Sorry if I missed it, but will the machine get up to full/normal ground speed in F or R eventually? Is everything moving normally with the F/R pedals and pedal dampener (if so equipped)?
Does it do this right after cold start, or only once warmed up?
If the loader and hydraulics work at normal full strength, you wouldn't think there's anything going on hydraulically.
It does get up to full speed eventually. I've eliminated the pedal linkage as a possibility by bypassing it all and engaging the HST right at the shaft coming out of the case.
/ Mahindra HST problem #9
Does it seem to have full power- torque to the wheels when it starts moving?
/ Mahindra HST problem #10
Not likely, but is it possible that the rims are spinning at the tire bead?
I would say no. It goes something like this: Press pedal all the way down, 2 seconds later it barely starts to move, ramps up to full speed over the next 5 seconds.
I was starting to think about a stuck relief valve inside the HST until I saw the charge pressure was fine.
Thats definitely not happening, but thats basically what it feels like. Like you're spinning tires on ice and they slowly gain traction.
/ Mahindra HST problem #13
Does charge pressure stay semi-constant when trying to accelerate vs sitting stationary?
Since I do NOT know how the HST is controlled on your tractor I can only guess and offer a couple of options.
1) The pedals drive or connect to a pilot control device on the HST. This pilot control has an orifice between charge circuit and control to limit response speed. If this is partially plugged it would affect operation in both directions and might limit torque output to the wheels.
2) Pedals connect to a potentiometer that feeds into an electronic controller that controls a proportional control on the HST. Again could have orifice between charge circuit proportional control same as option 1.
Doubtful is a relief valve since forward and reverse travel are two different relief valves.
3) it is electro proportional controlled and some ramp or parameter - output has changed affecting both directions
