RedRiver
fyi, check out this thread for more info that hasn't been posted here............two important things I see in that thread.
http://www.tractorbynet.com/forums/mahindra-owning-operating/124493-review-4500-a-2.html
Post #1
"Warrenty expired the month it started knocking and factory says "tough luck"."
Post #9 in the thread
"The engine started knocking last October but being out of work left a seriously deep hole in our finances so I let it sit until spring. "
Which is it?
if you are going to neglect to try and get it looked at and/or repaired under warranty who's fault is it?
fyi, I haven't seen any problems with the 4500 engines. The only Mahindra I've seen throw a rod in the 6 years I've been around them was a 5 year old 4505 that was a rental unit. It had been severely abused by both the owner and the people who rented it. Also they are changing the engines to adjust the emissions to the new EPA standards, I think you will realize sooner or later all brands are having to do this.
Regardless, your dealer should try their best to go to bat for you with Mahindra but sometimes its' hard to do that when the issue has not been brought to their attention for almost a year. The track record of avoiding a warranty issue for almost a year, leaving a tractor in the middle of the field all winter, and attempting to drive it even when you realize something major may be wrong is just not a good thing in the manufacturers eyes. Sometimes small simple problems turn into big expensive problems just due to neglecting to address the possible issue.
In the end, I hope you get this all sorted out and I wish you the best of luck but coming on the web and bashing a brand name is not the way to go about this especially considering your circumstances of what has not been done on your part.
Post #1
Which is it?
