Manual vs Hydro Transmissions
Status
Not open for further replies.
   / Manual vs Hydro Transmissions #51
I vote for manual. Our Ford 1300 had a rebuild (engine) about 3 years ago. We did the clutch then, for couple hundred dollars or less. Engine was less than a thousand. Still going strong otherwise, tractor is an 83 model.
   / Manual vs Hydro Transmissions #52
Hi All
Life with a tractor used to be a lot simpler.
After all, it was not too long ago we did not have Hydro Tranny's. Our dads and grandads never saw them. Thats only, if you are as old as I am.
We had several tractors on the farm at the time. Dad and Gramps were still working the family farm back in 1973. I was helping out on weekends and when something broke.. We had a 1941 9N, a Fordson Major, and a couple of IH row croppers. In regard to wearing a clutch out, I don't recall ever replacing one on any of our tractors. I had the 9N until two years ago. It had the original clutch in it when I sadly parted with it. (See attached pictures of the Mrs. & I saying Goodbye on the sad day) I am sorry now that I let her go. The offer was too good to pass up at the time.
Back in 1987, I had resleeved the engine and put adjustable valve lifters and new pistons & rings in her, replaced the PTO shaft and bearings, the splines were worn off the business end of the shaft, replaced the steering sectors and pinion, replaced the ignition wires and points and gave her a new coat of paint. When I had her torn down I looked at the clutch it still had life in it so I put her back together. All of the parts were available and tractors were designed to be worked on.
I guess, life of a clutch depends how you work a clutch and how much HP you got in front of it. The 9N had an eleven inch clutch and something like only 23 Hp. The tractors of today are not made to last like then.. Ford and Ferguson made that baby to last. And last they did. Buying a tractor decision was not hard, like Henry used to say about the old "T" Give them any color they want as long as it is black.
Think I will try to get her back if I ever enlarge the barn.
Thanks for the memorys.
Ray
   / Manual vs Hydro Transmissions #53
About the loss of power due to having an HST...
I have written on this before but feel inclined to repeat myself. Maybe it is just Kubota's SUPERIOR engineering...
B-U-T... My tractor is rated for 39.5 HP at the PTO. Now, if I had bought the more efficient GEARED tranny on the same model tractor I would have had 40 HP at the PTO. OOOOOOH I'm being robbed of 1/2 of a HP!!!
I don't think that short of a sensitive dyno test you could tell the difference. I certainly don't think an operator is going to perceive 1 1/4 % loss of power. If other brands of tractors lose a significantly greater percentage of their power in the hydraulics then that is a statement on their design.
I admit that I do not know the power loss of other makes of HST but truly doubt that any NAME BRANDS are particularly inferior to Kubota in power transmission.
MYTH BUSTED - - - HST is not a big loss of power
As to reliability... Maybe I'm just luckier than most (nothing else tends to support that hypothesis) but I have mistreated my Kubota with a vengence (just thrash around on it like a madman) and the HST has NEVER required anything but filters and fluids.
About the idea that it doesn't make a difference in manuvering, especially tight manuvering... I can heel and toe with the best of them and double clutch too. I can drive a non synchro tranny pretty grind free B-U-T... I have no illusions about any manual tranny tractor, even a shuttle shift or automatic clutch model being as easy to use in close in manuvering. I'm not disagreeing with any previous poster's comments about their manual shifting abilities and speeds. I do claim that the HST is easier under all manuvering conditions and will let virtually ANYONE perforn at or above the level of the best manual tranny user with minimal training and a lot less actual work.
If you do not anticipate tractor use with a FEL or any mowing with obstacles and mostly are into row cropping or dragging implements through the dirt for hours on end wiith very few reversals in direction, then by all means the standard gear tranny is the best fit. Most folks would agree that it would outlive the HST in that service and be cheaper to maintain.
So what if you save a few bucks in purchase price and another few bucks in lifetime maint costs if you give up a lot of convenience and capability. You can regret at your leisure what you decided in haste. You will have hundreds if not thousands of hours of seat time over the expected life time of your tractor to wish you'd opted for a better fit, WHATEVER THAT IS if you don't choose what you want/need instead of what you can get by with.
Pat
   / Manual vs Hydro Transmissions #54
Pat
Hi Pat, where have you been? How have you been?
   / Manual vs Hydro Transmissions #55
Check out tractor data or nh web sites for specs on nh 45 gear vs hst .The hydro is what i had in the 40d series it had alot more dirt shoving power than the old 3ooo ford and would out work a 2wd 555b backhoe on hills .Loss of power was not the problem i needed more hp at the pto so i traded up to a tc55 the 45 should have plenty .The good thing about the 45d hydo you can add a mid mount pto if you want a belly mower or a front mounted snow blower .There better on hills and next to foundations for more precise work the gear transmission would be a better choice for more field work in my opinion although it has a shuttle and the dealer said it would be better for loader work.You will loose about two or three hp for the hydro.I hope this helped .
   / Manual vs Hydro Transmissions #56
Well, I for one am on my 2nd HST and absolutely love it. The 1st didn't fail - just traded up. Big fun with lots of seat-time this weekend -I had 5 yds of stone delivered and with the ease of the rocker pedal on my HST Kubota I was able to get it all moved and smoothed in less than an hour. Also many post holes dug - not a big job, but you certainly couldn't tell any power lost!
-Brian
   / Manual vs Hydro Transmissions #57
I have no complaints with my small geared tractor, but I did find a situation where HST would be nice that I don't think has been mentioned. While snowblowing in reverse into a packed pile I could have used an even slower ground speed to keep my RPMs up. Keep in mind intermittantly engaging the clutch also intermittantly stops the pto. My workaround was to take smaller bites so as not to strain the engine. Of course a tractor with more than 15HP would help too.
   / Manual vs Hydro Transmissions #58
RaT, Doin' fine thanks. Raisin' a dozen black calves, mostly Angus (maybe a touch of Limousin or ???.) Pidling on the house projects. Surviving the ice storm. Gettin' my but kicked trying to download digital video into computer.
Still working on my interior storm shutters. (Sore back, darn things are HEAVY.)
Hope all is going well with yoiu this new year of 2007.
PAT
   / Manual vs Hydro Transmissions #59
swedish-fish said:
... Keep in mind intermittantly engaging the clutch also intermittantly stops the pto...
Really? I read a discussion a while ago about 'live PTO' which keeps running with the clutch in. Or is it 1/2-way in? I have an HST with 'live PTO' and the PTO keeps running if I put the clutch in. I don't do that much, but I did try it after reading about live PTO.
-Brian
   / Manual vs Hydro Transmissions #60
-Brian
On gear transmissions A "non-live" PTO will shut off when the clutch is pushed in.
A "live" PTO with a 2 stage clutch will continue to run when the clutch is pushed half way in, and will shut off when the clutch is pushed all the way in.
An "independant" PTO usually is turned on by a switch on the dash, and will continue turn run reguardless if the clutch is in or out, and will run until the switch is turned off..
Status
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
2002 Bobcat 763 Compact Skid Steer (A55314)
2002 Bobcat 763...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55314)
Koyker Loader...
